Tapping Noise
Old Oct 13, 2006 | 08:44 PM
Touge Tuning's Avatar
Default Tapping Noise
I just noticed a tapping noise that comes on at around 3000rpm and is only there when you are pressing the accelerator. I think it may be a loose valve rocker arm as I did a valve adjustment a few months ago and it may have loosened up. I am hoping it is not "rod knock" or a spun bearing as its not that loud but an annoying tapping very quickly.
Old Oct 14, 2006 | 04:43 AM
Ovrbst_T66's Avatar
Default Re: Tapping Noise (Stealth1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth1 &raquo;</TD></TR><TR><TD CLASS="quote">I just noticed a tapping noise that comes on at around 3000rpm and is only there when you are pressing the accelerator. I think it may be a loose valve rocker arm as I did a valve adjustment a few months ago and it may have loosened up. I am hoping it is not "rod knock" or a spun bearing as its not that loud but an annoying tapping very quickly.</TD></TR></TABLE>If this is a b16 head most likely its the lma's.
Old Oct 14, 2006 | 05:04 AM
B18b1 engine
Old Oct 15, 2006 | 11:04 AM
well, my mechanic seems to be certain its a bearing. Only happens when you are on the throttle and its most apparent at 3000rpm. Looks like I might have to pull this bad boy and rebuild with new bearings and drop in a B20b.
mtkhalid
16
Sep 29, 2008 10:47 PM
user 4747283
Feb 18, 2007 07:21 PM
vtecn8ive
Oct 8, 2006 03:14 PM
Rasta
Oct 7, 2004 08:14 PM
mrbsponge
Jan 28, 2004 01:26 PM
