OBX question
Old Oct 13, 2006 | 04:08 PM
Got_soy's Avatar
Default OBX question
i know some people are having the diff itsself machined, where aer you machining from?
Old Oct 13, 2006 | 04:16 PM
BlueCrxNC's Avatar
What are you trying to accomplish?
I'm one who had some machining done.
Old Oct 13, 2006 | 06:13 PM
Got_soy's Avatar
Default Re: (BlueCrxNC)
im trying to find out were you removed material to get the clearance to run an oem shim
Old Oct 13, 2006 | 06:56 PM
BlueCrxNC's Avatar
Edited fasted image of the OBX LSD I could find. (Apologize to owner )
Circles indicate face I had machined. ONLY this side!
MistaBone and others are using shims meant for other things that will work instead of doing any machining. I had a VERY hard time finding a machine shop willing to do the work anyway. NOTE: I also had them turn down the "X" on each end (Original form is 40mm. I was/am using a 35mm bearing trans case) but you DON'T need that.
Old Oct 14, 2006 | 06:13 AM
Got_soy's Avatar
cool, thanks
Old Oct 14, 2006 | 07:23 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">
MistaBone and others are using shims meant for other things that will work instead of doing any machining. I had a VERY hard time finding a machine shop willing to do the work anyway. NOTE: I also had them turn down the "X" on each end (Original form is 40mm. I was/am using a 35mm bearing trans case) but you DON'T need that.</TD></TR></TABLE>
I went about it a different way. I put a shim between the diff and the bearing and pitched the honda shim.
Old Oct 15, 2006 | 01:23 PM
BlueCrxNC's Avatar
Default Re: (Chiovnidca)
Interesting. So what kind of shim did you use? I assume that it was just enough to take up the bearings seat.
Old Oct 15, 2006 | 03:52 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">Interesting. So what kind of shim did you use? I assume that it was just enough to take up the bearings seat.</TD></TR></TABLE>
It was in my toolbox and was the perfect size. It was from a mercruiser or mercury outdrive from when I used to rebuild them. It left it with .003" clearance.
Old Oct 15, 2006 | 04:41 PM
BlueCrxNC's Avatar
That's awesome
Old Oct 15, 2006 | 05:47 PM
Got_soy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">It was in my toolbox and was the perfect size. It was from a mercruiser or mercury outdrive from when I used to rebuild them. It left it with .003" clearance.</TD></TR></TABLE>
you happen to know where people could get them?
Old Oct 15, 2006 | 06:11 PM
Chiovnidca's Avatar
Default Re: (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">you happen to know where people could get them?</TD></TR></TABLE>
A boat dealer I suppose, dont remember which bearing the shim was for though.
sydegsr
Feb 23, 2006 11:02 PM
1SlowSi
Mar 30, 2005 07:18 PM
anotheredhatch
Welding / Fabrication
21
Dec 19, 2004 09:36 AM
Fraggle
14
Feb 24, 2004 04:42 PM
