I need somebody to helpme with my <p05,p06> ecu
Old Oct 13, 2006 | 08:18 AM
jonrv13@'s Avatar
Default I need somebody to helpme with my <p05,p06> ecu
I need somebody to helpme with my &lt;p05,p06&gt; ecu,I need to see the instructions to put the chip that have just bought thanks ,this is because i just can get the instructions for the p28
Old Oct 13, 2006 | 10:21 AM
rmcdaniels's Avatar
Default Re: I need somebody to helpme with my <p05,p06> ecu (jonrv13@)
Is it for a VTEC motor?
Old Oct 13, 2006 | 10:23 AM
jonrv13@'s Avatar
Default Re: I need somebody to helpme with my <p05,p06> ecu (rmcdaniels)
no is not vtec
Old Oct 13, 2006 | 10:28 AM
rmcdaniels's Avatar
It should be the same for a P06 as for a P28. I've converted P06's to P28's, then chipped them. It's prety much he same ECU except for the extra components for VTEC. You can check Xenocron's Web site for some good instructions.
Old Oct 13, 2006 | 10:29 AM
jonrv13@'s Avatar
thanks a lot i will do that
Old Oct 13, 2006 | 11:09 AM
mmuller's Avatar
Mad Scientist
http://www.pgmfi.org/twiki/bin...bHome
all the info youll ever want.
P06 can be converted to vtec if needed
P07 is a totally different beast that runs a wideband O2 stock and is not currently supported
Modified by mmuller at 7:43 PM 10/13/2006
Old Oct 13, 2006 | 12:13 PM
Furyof4's Avatar
Default Re: I need somebody to helpme with my <p05,p06> ecu (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">http://www.pgmfi.org/twiki/bin...bHome
P05 is a totally different beast that runs a wideband O2 stock and is not currently supported</TD></TR></TABLE>
The P05 is from the cx and has a single wire narrow band, it can be chipped and converted easily.
The P07 is the one from the vx which has a wideband, not supported.
Old Oct 13, 2006 | 03:43 PM
mmuller's Avatar
Mad Scientist
Default Re: I need somebody to helpme with my <p05,p06> ecu (Furyof4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">The P05 is from the cx and has a single wire narrow band, it can be chipped and converted easily.
The P07 is the one from the vx which has a wideband, not supported.</TD></TR></TABLE>
oops your right; corrected
Old Oct 14, 2006 | 04:46 AM
Ovrbst_T66's Avatar
P05,p06 has 4 wire 02 sensor
p07 has 5 wire wideband 02
Old Oct 14, 2006 | 04:53 AM
mmuller's Avatar
Mad Scientist
Default Re: I need somebody to helpme with my <p05,p06> ecu (danny_t66)
regardless, 4 wire O2 can be added to the single wire one
baulum
Engine Management and Tuning
Feb 16, 2020 08:48 PM
JDMKid71
16
Feb 21, 2006 04:12 PM
vietdragontekx
Dec 21, 2005 05:52 AM
strebor95
Mar 3, 2005 03:42 PM
NatedoggAZ
Jul 31, 2003 05:01 AM
