LSD removal
Old Oct 13, 2006 | 02:44 AM
garyc17's Avatar
Default LSD removal
Can my Integra R still work with my LSD removed?
Old Oct 13, 2006 | 04:40 AM
D's Avatar
D
Default Re: LSD removal (garyc17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Can my Integra R still work with my LSD removed?</TD></TR></TABLE>
Define 'work'
Old Oct 13, 2006 | 04:49 AM
George Knighton's Avatar
H-T Order of Merit
I'm not sure what you mean. Honda Torsen axles are an integral part of the differential so, no, you cannot "remove" the LSD and still have a working transmission to the ground.
If you have had a catastrophic failure and you're wondering if you can uses a Honda open diff as a replacement then, yes, that will work...you just won't be able to put all the power down as well as you were able to do it before.
Tell us more about what's going on.
Old Oct 14, 2006 | 05:05 AM
garyc17's Avatar
Default Re: LSD removal (George Knighton)
I have an aftermarket clutch type LSD in my tranny now. I wish to remove it and have a tranny with no LSD. Can I just remove it from my tranny and have a car that still moves after that?
Old Oct 14, 2006 | 06:41 AM
RagingAngel's Avatar
no
Old Oct 14, 2006 | 06:49 AM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">I have an aftermarket clutch type LSD in my tranny now. I wish to remove it and have a tranny with no LSD. Can I just remove it from my tranny and have a car that still moves after that?</TD></TR></TABLE>
no, you would need to put another b-series differential in there
Old Oct 14, 2006 | 11:32 PM
garyc17's Avatar
Could you define differential? Would that mean final drive?
Old Oct 15, 2006 | 12:41 AM
Default Re: (garyc17)
no, it means the piece that you intend to remove.
aka, the LSD, aka the diff, aka differential.
and in order to have it work with your current sized final drive, it would have to be from a GS-R as LS/16A are sized differently.
Old Oct 15, 2006 | 02:02 AM
H-T Order of Merit
I'm not sure why you'd want to remove your clutch-type LSD. Does it point you too quickly because it works off throttle, or what?
Did you buy a high performance track car that doesn't suit you or something?
What you <u>could</u> do if you don't want your clutch-type LSD is trade it with somebody who has an open diff or an OEM Honda Torsen axle (a stock ITR LSD). Somebody who has gone far enough with his car's development that he might want a clutch LSD might even be willing to help you with the labour.
What exact LSD is this, and what axle ratio do you have?
Old Oct 15, 2006 | 05:35 AM
garyc17's Avatar
I have a 4.6 Final Drive with a Spoon LSD. I was thinking if its better in the long run to have a service free stock ITR LSD instead of having to replace the clutch plates on the Spoon LSD. Also, I am having a hard time choosing a tranny fluid that can protect my syncros and LSD at the same time. For Syncro protection, my LSD doesn't work well, for LSD protection, it jerks like crazy on slow turns when the MTF has not warmed up.
Old Oct 15, 2006 | 06:07 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">I am having a hard time choosing a tranny fluid that can protect my syncros and LSD at the same time. For Syncro protection, my LSD doesn't work well, for LSD protection, it jerks like crazy on slow turns when the MTF has not warmed up.</TD></TR></TABLE>
As I've told you in 2 other threads, I've been using Redline MT-90 for over 100,000 miles with no adverse affects. *shrug*
Old Oct 15, 2006 | 08:05 AM
Default Re: LSD removal (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">As I've told you in 2 other threads, I've been using Redline MT-90 for over 100,000 miles with no adverse affects. *shrug*</TD></TR></TABLE>
Haha don't you hate that?
People who ask for advice and then insist that you've gotta be wrong and keep digging....
for persistence I guess....
Old Oct 16, 2006 | 10:23 AM
garyc17's Avatar
Hey dude, I've not said I don't believe in your advise. I'm just trying to seek some advise on going around the problem instead of having to use certain fluids. I still remembered your recommendation for MT-90.
sonny0330
May 10, 2008 12:00 PM
kamAccord
Mar 8, 2007 06:05 AM
hidiouskinky
Sep 18, 2006 07:47 PM
.Ryan
12
Apr 3, 2005 06:57 PM
mr devious illusions
Mar 16, 2004 11:27 AM
