where to ground amp in 5th gen hatch
Old May 3, 2002 | 01:41 PM
Mike D's Avatar
Default where to ground amp in 5th gen hatch
holy **** is this frustrating, my amp is going into protect mode and the only thing i can think of is the shitty *** ground.
So where did you guys ground your amps?
TIA
Mike D
Old May 5, 2002 | 12:45 AM
sparq's Avatar
Default Re: where to ground amp in 5th gen hatch (Mike D)
Where are you grounding the amp?
What are you using to ground the amp? Can you be more specific... if it going into protect mode as soon as the system comes on, after your driving for along time -- help me help you my friend
Old May 5, 2002 | 07:37 PM
Jonathan_ED3's Avatar
TIA
Mike D
remember...don't let the ground cable be more than 18 inches long, or your chances of noise increase. anyway, if you're close enough to the back seats, run the ground cable underneath one of the seatbelt bolts underneath the rear bottom seat cushion. ...then bolt that bad boy down again...it's a GREAT place for a good ground
Old May 6, 2002 | 09:47 AM
Steve's Avatar
I took out the bolt that holds the spare tire down and used that existing hole to bolt my ground down. Works perfect.
Keangdawizes
Audio / Security / Video
Apr 28, 2008 09:41 AM
92eg_b16
Mar 28, 2008 08:20 PM
thatasiankidtony
Nov 23, 2006 10:09 AM
ironryder
Apr 26, 2005 01:26 PM
juniordc2
22
Jul 18, 2004 09:58 AM
