help please!
Old Oct 12, 2006 | 08:42 PM
crxsi777's Avatar
Default help please!
just put a coupe bumper on my 93 sedan, and installing the CIVIC OEM PROJECTOR FOG LIGHTS FOGLIGHTS
cut the bumper, mounted em no problem, installed the relay, conected to the battery, fished the wires inside under teh steering column, now there is a black wire - which needs to be gounded ; red wire connects to the foglight switch on the dash, and there is a yellow wire - where do i connect it to?
here is some pix i took
Old Oct 12, 2006 | 08:44 PM
instrument's Avatar
i can't help
but for gods sake i hope you have an alarm on that civic living in n.j.
alarm
kill switch
something
please.
thanks
good luck with your lights.
Old Oct 12, 2006 | 09:28 PM
crxsi777's Avatar
Default Re: (instrument)
here just took a few...unfortunately the lights arent on, becasue i dont know where to hook up the yellow wire..someone help please!
Old Oct 12, 2006 | 09:31 PM
EX-T's Avatar
Default Re: (crxsi777)
the yellow one probably goes to your dimmer switch +12V....
Old Oct 12, 2006 | 09:39 PM
crxsi777's Avatar
Default Re: (EX-T)
so i need to splice the yellow into that wire? what color is it do you know?
Old Oct 12, 2006 | 11:07 PM
graveltravel2's Avatar
that must be a cheap set... mine never had a yellow wire. it simply had an extra wire with a plug that plugged into a panel under the dash.
those must not be depo fog lights.
and you must have a ex/eg front bumper. 4 door civics have "ferio" fog lights that mount in the grill.
Old Oct 13, 2006 | 12:51 AM
Harryflores's Avatar
Default Re: (graveltravel2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graveltravel2 &raquo;</TD></TR><TR><TD CLASS="quote">you must have a ex/eg front bumper. 4 door civics have "ferio" fog lights that mount in the grill.</TD></TR></TABLE>
word
Old Oct 13, 2006 | 11:37 AM
crxsi777's Avatar
Default Re: (Harryflores)
i got the bumper of a 2 door 94 ex
i just cant fiure out why im not getting power? the switch doesnt light up when i press it, and there is power from the battery going to the relay, i tested it with a test light. the yellow wire i tried plugging into the female plu above the fuse box under steering wheel column. still nothing... can anyone help me?
Old Oct 13, 2006 | 11:46 AM
deryck324's Avatar
sory man mine doent have a yellow wire , where does it come from-the relay?
Modified by deryck324 at 7:09 PM 10/14/2006
draxo
Jan 11, 2008 11:30 AM
crxsi777
12
Oct 13, 2006 08:57 AM
gisserhatch
Jun 25, 2006 08:14 PM
saywhat
Feb 8, 2005 10:05 PM
eternaljihad
Audio / Security / Video
Dec 15, 2004 02:05 PM
