Type R Parts...
The header im sure will bolt to the head, you may have some problems with the fuel rail due to the differences between p72(gsr) and p73(itr) or b16 style intake manifold. The butterfly p72(gsr) manifold being the outcast of the b series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shoxnzforme »</TD></TR><TR><TD CLASS="quote">I know this may sound weird but will oem GSR headers bolt right up to a type R motor?.... how about an oem GSR fuel rail????.. thanks</TD></TR></TABLE>
I have an ITR exhaust manifold if you're interested.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cKoupe »</TD></TR><TR><TD CLASS="quote">The header im sure will bolt to the head, you may have some problems with the fuel rail due to the differences between p72(gsr) and p73(itr) or b16 style intake manifold. The butterfly p72(gsr) manifold being the outcast of the b series.</TD></TR></TABLE>
Can anyone confirm this? I was looking for an OEM fuel rail for the p73, but I think I have access to a p72 and was going to try to use that instead. I figured the mounting point would be the same even though the two intake manifold's are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exies »</TD></TR><TR><TD CLASS="quote">
Can anyone confirm this? I was looking for an OEM fuel rail for the p73, but I think I have access to a p72 and was going to try to use that instead. I figured the mounting point would be the same even though the two intake manifold's are different.</TD></TR></TABLE>
I believe they will fit. Not 100% but close
I am pretty sure that the exhaust manifold will bolt to the head without any problems. I am not sure if it will line up properly with the cat though. The fuel rail for the P72 head (GSR) I believe is different. You should look for an ITR fuel rail or an EM1 Civic Si fuel rail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote">I am pretty sure that the exhaust manifold will bolt to the head without any problems. I am not sure if it will line up properly with the cat though. The fuel rail for the P72 head (GSR) I believe is different. You should look for an ITR fuel rail or an EM1 Civic Si fuel rail.
The only reason I thought they would fit is because we took one off of an old b16 and put it on a GSR.
I dont know?
</TD></TR></TABLE>The only reason I thought they would fit is because we took one off of an old b16 and put it on a GSR.
I dont know?
All right, I'll look for those fuel rails instead.
And the exhaust manifold, I also believe at it will bolt up with out a problem, but the length of the gsr header is different. They are shorted compared to the LS / ITR and probably won't reach the cat. I believe it was in 00+ when the gsr header was the same length as the other Integra's.
</TD></TR></TABLE>All right, I'll look for those fuel rails instead.
you can look up the fuel rail part #'s on http://www.barancoacuraparts.com and see if they are different. that would be a good indicator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC »</TD></TR><TR><TD CLASS="quote">you can look up the fuel rail part #'s on http://www.barancoacuraparts.com and see if they are different. that would be a good indicator.</TD></TR></TABLE>
Part Number Image Description List
Price Our
Price Into Cart
16620-P72-010 PIPE ASSY., FUEL 189.38 150.56 Qty
The above part fits the following Model / Year combination(s).
Click on the desired combination to view the corresponding trim related information
Model Year
INTEGRA '96 - '01
INTEGRA '96 - '01
INTEGRA 4DR GS-R LEATHER, INTEGRA 3DR GS-R LEATHER, INTEGRA 4DR GS-R, INTEGRA 3DR GS-R, INTEGRA 3DR TYPE R
Price Our
Price Into Cart
Model Year
INTEGRA '96 - '01
INTEGRA '96 - '01
Ha, I should have thought of that. Thanks guys
To the OP, you can do a search at http://www.barancoacuraparts.com. It may or may not fit depending on what year header you have.
boosh
Sep 19, 2007 10:56 PM
hybrid98
Sep 12, 2006 08:16 AM
mcxmouse
Feb 19, 2006 07:22 AM
