after market pistons
Old Oct 12, 2006 | 07:59 PM
Drew17th's Avatar
Default after market pistons
im going all motor and i was wondering what are some good after market high compression pistons???
Old Oct 12, 2006 | 08:07 PM
EG2Driver's Avatar
Default Re: after market pistons (Drew17th)
just use OEM ITR or CTR pistons. But thats for B series. What engine do you have?
Old Oct 12, 2006 | 08:17 PM
Drew17th's Avatar
Default Re: after market pistons (DeadEnd9009)
gsr.... im building the head with skunk2 valves, retainers and springs... so i was curious if i should go after market pistons or itr..... im going all motor high compression...
Old Oct 12, 2006 | 09:36 PM
JDMSedan's Avatar
skunk 2 stage 2's would go really good with your head setup.
Old Oct 12, 2006 | 09:50 PM
Drew17th's Avatar
Default Re: after market pistons (4drEG=gettinladies)
i was just looking at JE 12.4 to 1 pistons.... what must be done to use pistons with compression that high without any risk!!!
Old Oct 12, 2006 | 10:05 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th &raquo;</TD></TR><TR><TD CLASS="quote">i was just looking at JE 12.4 to 1 pistons.... what must be done to use pistons with compression that high without any risk!!!</TD></TR></TABLE>
head work... valves, retainers, springs. i would suggest arp head bolts since your in there. that and your gonna wanna chip an ecu so you can tune. you do realize with that kinda compression fuel managment needs to be looked at aswell... 94 octane is gonna be your friend from now on
Old Oct 13, 2006 | 12:50 AM
Drew17th's Avatar
Default Re: after market pistons (Bond)
is the 11.5 JE pistons be a good suit for what im doing??? with those and a 2 layer head gasket with built gsr head what would be a rough estimate on compression.... like i said im doing skunk2 valves springs and retainers on the head but i still dont know what kinda cams to use... and then the block i was gonna use stock crank with aftermarket or ITR pistons and do a fresh rebuild!!!!
Old Oct 13, 2006 | 08:53 PM
Bond's Avatar
well you can go to redpepperracing.com and use their comp. calculator and try all sorts of setups. it's ur build so do as you please. as for a headgasket just stick with a stock metal honda headgasket. trust me though....just please invest in some arp head bolts bcuz the higher the comp. the more the head could lift. i would just suggest using itr pistons but like i said that would be my build and not yours. keep asking questions and researcha and u'll find the right setup you want. what's ur hp goal???
Old Oct 13, 2006 | 08:58 PM
Syndacate's Avatar
Just a thought...might wanna tell us for what engine...and what the app is (daily driver?)...and what yoru goals are?
You know?
...Just a thought...
Maybe even what kind of engine this is going into?
Old Oct 13, 2006 | 09:36 PM
cambopheonix56's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Just a thought...might wanna tell us for what engine...and what the app is (daily driver?)...and what yoru goals are?
You know?
Maybe even what kind of engine this is going into?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">just use OEM ITR or CTR pistons. But thats for B series. What engine do you have?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th &raquo;</TD></TR><TR><TD CLASS="quote">gsr.... im building the head with skunk2 valves, retainers and springs... so i was curious if i should go after market pistons or itr..... im going all motor high compression...</TD></TR></TABLE>
cincyb20ek
Jul 12, 2010 06:31 PM
stonet149
12
Nov 2, 2008 09:29 PM
CXtypeR
Jan 4, 2007 07:11 PM
7mile
Feb 6, 2006 09:08 PM
trooper0641
12
May 10, 2004 09:41 PM
