PLEASE HELP.....CRANK PULLY BOLT
Old Oct 12, 2006 | 06:50 PM
beastraiser's Avatar
Default PLEASE HELP.....CRANK PULLY BOLT
I have been working the mini-mi on my 88 crx si trying absolutly every thing i could think of please help me with this crank pully bolt. i have a 380 ft/lb impact gun and a 18'' strongarm i've heated it up, and nothing, i've pulled on it so hard that the engine actually jumpsa good 3'' ,FYI need new engine mounts, the engine is still in the car with no head and a stuck crank pully. also it is the 88 so the pulley is smooth inside and out so there is no special hexagon tool i could use either. it is so frustrating its takin' all my power not to just start beatin' the thing with my sledge hammer. PLEASE HELP ME ANY OTHER SUGGESTIONS WILL BE DOULY NOTTED AND MORE THEN LIKELY TESTED. thanks.
Old Oct 12, 2006 | 06:57 PM
rsxcrx's Avatar
Default Re: PLEASE HELP.....CRANK PULLY BOLT (beastraiser)
i used a industrial strap wrench to hold my pulley. try the tool rental places thats where i got mine.
Old Oct 12, 2006 | 07:04 PM
Loserkidwac's Avatar
Default Re: PLEASE HELP.....CRANK PULLY BOLT (rsxcrx)
There is wholes in the crank pulley correct...my 91 Si had them and not the hex shape...what I did was got 2 bolts put the through the holes and then put a piece of steel between them, long enough to hit the floor or the frame...as you turn the crank one bolt hits the one side and the other hits the other side..or if you have a piece of steel with whole in it bolt it to the crank pulley...either way once the pipe/steel hits the fram or floor give it a nice quick snap on the bolt and you should be able to break it loose...usually have the car in gear with someone smashing the brakes and a nice 6' to 10' breaker bar
Old Oct 12, 2006 | 07:33 PM
highrev1987's Avatar
Default Re: PLEASE HELP.....CRANK PULLY BOLT (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">There is wholes in the crank pulley correct...my 91 Si had them and not the hex shape...what I did was got 2 bolts put the through the holes and then put a piece of steel between them, long enough to hit the floor or the frame...as you turn the crank one bolt hits the one side and the other hits the other side..or if you have a piece of steel with whole in it bolt it to the crank pulley...either way once the pipe/steel hits the fram or floor give it a nice quick snap on the bolt and you should be able to break it loose...usually have the car in gear with someone smashing the brakes and a nice 6' to 10' breaker bar </TD></TR></TABLE>
thats what i did
Old Oct 12, 2006 | 07:49 PM
Default Re: PLEASE HELP.....CRANK PULLY BOLT (highrev1987)
tried that and i blew apart the two bolts holding it in plus my 18'' breaker bar. but i'll go to rent-a-tool tommarow and see if i find one of those industrial strap wrenches. thanks please keep the responses coming. considering as last resort towing it to Canadian tire and using one of there 1600ft/lb impact guns but that like 80 buck of labour-discount
Old Oct 13, 2006 | 12:48 AM
zurud's Avatar
I broke the holes in my crankpulley too using methods menrion above. Since you already have the head out, Just take the whole engine out and put a wrench between clutch cover bolt and engine bolt. Works for me. Search on how to remove crankpulley bolt in the forums and you'll find tons of ideas.
Old Oct 13, 2006 | 12:57 AM
13g-crx's Avatar
I used a chain wrench on the cranck pulley and a 3/4" drive breaker bar with a 4' pipe on it.....and a whole lot of straining.
Old Oct 13, 2006 | 04:59 AM
Default Re: (13g-crx)
what every you do make sure that the pulley isnt thrown off balance it will wreck your lower internals
Old Oct 13, 2006 | 07:06 AM
89 civic si's Avatar
Default Re: (highrev1987)
ive had many problems with these, i would get it towed to a shop where they have a gun with some ***, ive had to do this many times...i took it to a shop and didnt get charged the guy was cool...
Old Oct 13, 2006 | 09:56 AM
Default Re: (89 civic si)
thanks guys for the advice im going to rent-A-tool today to get either a stronger impact gun or a chain wrench, hopefully it all goes smothly if not check the forum again tonight
Old Oct 13, 2006 | 09:59 AM
philkehn's Avatar
its factory torqued to 600 pounds so make sure you at least make those specs
Old Oct 13, 2006 | 10:46 AM
Default Re: (philkehn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">its factory torqued to 600 pounds so make sure you at least make those specs</TD></TR></TABLE>
Seriously?? The tq specs for putting it back on are 2 step first 145ft/lbs and loosen and retourqe to 130ft/lbs
Old Oct 13, 2006 | 02:31 PM
CO Wagofan's Avatar
I just got mine out last weekend. I read all these horror stories but came with my own method - which worked like a charm.
I put 1 bolt in one of the pulley's blind holes (like a 3/8" dia bolt) - propped my jack handle underneith the bolt (verically from the floor to the bolt - bolt at the 9 o'clock position) to hold the pulley in place. I used my 1/2" drive with a bar (total of 18" length) and my leg to push - and pop it came loose &lt;30sec.
I realize that some people have bolts that are REALLY stuck - but this worked for me. oh-yeah, I soaked it with some PB Blaster for about 1hr prior.
goood luck
Old Oct 16, 2006 | 10:34 AM
Default Re: (CO Wagofan)
no such luck with a bigger impact gun, my tank was too small. however i'm gonna take it to work and use our massive compressors there i just have to hope the bossman lets me. i'll have to get it towed there and back free one way but 50 bucks the second. oh well it should work out and ill convience my boss today so i can do it tommary if it doesn't work more suggestions world be greatly appreciated.
Old Oct 16, 2006 | 11:37 AM
Max Kling's Avatar
Default Re: (beastraiser)
I love my big tank and big impact, NEVER had a problem, and if I did I have a acetylene torch.
goldfinger93030
Feb 13, 2010 06:39 AM
WRXRacer111
23
Jan 20, 2006 02:36 PM
Riceburner247
May 30, 2004 05:58 PM
Lsos
Nov 14, 2002 09:03 AM
Padawan
Jul 26, 2001 06:13 AM
