just hooked up hondata and I am throwing codes? HELP!
The cel light has actually been on since the T1R exhaust was installed b/c it eliminated one O2 sensor, so I was like ok no big deal. Now after I installed my hondata and was running some datalogging it showed a Knock Sensor Error and Oxygen Sensor Heater. I know the OSH is a simple fix I replaced it on my old b16 delsol but is it b/c of the O2 sensor not there that it is throwning both codes out? The car is running fine, a little rich but Vtec and everything is normal. So do I need to even worry about either one? or is one or both being caused b/c of that O2 sensor missing? I also tried to clear DTC's but they came right back on. Any help would be appriciated. Thanks.
Modified by TypeRguy97 at 11:43 PM 10/19/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LootR0435 »</TD></TR><TR><TD CLASS="quote">what basemap are you using on hondata, my understanding is that most tuners eliminate the knock sensor.</TD></TR></TABLE>
i have heard that as well, but why?
im just using the itr basemap. Could that be the reason for the knock sensor, b/c of the base map and with my exhaust is making the car run richer triggering the knock sensor?
Generally this is true, when you are trying to get a solid tune, you do not want the ECU to take control of anything, especially something as important as ignition timing.
ah yea thats what I thought but it is deffinitly showing a knock sensor so thats why im tring to figure out whats going on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRguy97 »</TD></TR><TR><TD CLASS="quote">ok, so how do i disable it?</TD></TR></TABLE>
Open Romeditor. Open your Rom. Click on the options tab. Check the box to disable the knock sensor. Save the Rom. Burn a chip with the new Rom.
