Need help on purchasing spark plug and wire!!!!!!!!!!!!!!!
Old Oct 12, 2006 | 11:17 AM
yuen's Avatar
Default Need help on purchasing spark plug and wire!!!!!!!!!!!!!!!
Hello to all,
car just hit 150 000km (complete stock), feeling is time for a tune up, just want to know what brand of spark plug and wire u guys would recommand (stock,Ngk, deso, bosch,etc.... ) , where is the best place to get them online. thxxxxxx
Old Oct 12, 2006 | 11:19 AM
TYPE-R#945's Avatar
Default Re: Need help on purchasing spark plug and wire!!!!!!!!!!!!!!! (yuen)
I GO WITH ORIGNAL NGK AND OEM WIRES IF NOT NGK WIRES WOULD DO GOOD TOO
Old Oct 12, 2006 | 04:51 PM
pyitrboy's Avatar
if your gonna buy wires; buy the stock...I hardly ever change wires in our
delarship at Honda, but I do notice more aftermarket wires breaking... not sure
about the more expensive ones though. Replace old plugs with stock also. I sometimes see engine code misfire with other brands other than Japanese plugs.
Old Oct 12, 2006 | 05:37 PM
RTW DC2R's Avatar
stock or you could even save a few bucks and run a NGK copper plug bkr7e-11 and probably wont notice a difference (the plug I use on my turbo setup).
Old Oct 12, 2006 | 05:44 PM
88 rex's Avatar
Default Re: (RTW DC2R)
http://www.clubplug.net
<----NGK wires and plugs
Old Oct 12, 2006 | 06:17 PM
iperez's Avatar
I too would suggest OEM NGK but if you want something different, I went with MSD 8.5mm wires and have had a very good result with them. I've had them for over 2 years trouble free.
Old Oct 13, 2006 | 09:37 AM
allm0torGSR's Avatar
Default Re: (iperez)
NGK = OEM Honda replacement brand.
And NGK wires are sexy blue.
Got my NGK parts at http://www.sparkplugs.com
Old Oct 13, 2006 | 10:30 AM
92TypeR's Avatar
FSAE
Default Re: (LunchboxZT)
NGK wires
NGK BKR7E-11
Old Oct 14, 2006 | 09:31 AM
LunchboxZT's Avatar
Default Re: (92TypeR)
I'm comming up on 100 ,000 miles myself and going to be doing plugs, wires, timing belt, water pump, valve adjustment, leakdown, etc.
Question on the NGK wires.
http://www.sparkplugs.com/results_app.asp
Realized Link doesn't work
Here is what I am refering too
Are the NGK Ultimate / Racing wires really that much better to pay $60 more? than the Premium set? I am using all stock internals with mostly bolt on's. I was reading and it sounds like the Ultimate ones are good, but how much better can they be than the Premium ones?
Old Oct 14, 2006 | 09:40 AM
92TypeR's Avatar
FSAE
The premium wire set is perfect.
I believe the ultimate is similar to the Spoon wires, where each post is individually grounded.
Old Oct 14, 2006 | 09:59 AM
RagingAngel's Avatar
the power cables in the ultimate class is the JDM darker blue cables with no individual grounds.
they are similar if not the same as the first generation "Spoon" wires. There was an independent test done that show that this was the best performing wire set a few years ago FWIW.
Old Oct 14, 2006 | 11:20 AM
type B16's Avatar
im also in the market for plugs and wires
is it worth spending the money for ngk power cables and bkr7 iridium for my jdm itr?
Old Oct 14, 2006 | 12:08 PM
I know a bunch of people personally (as in they will let me drive their cars ) who continue or have used the power cables with "success."
I firmly believe that parts like this *can* give measureable power gains, but whether you can actually detect that is another issue.
What they do give is better and smoother (here we go again) throttle response. How can you measure that though? I personally have kept using the Spoon wires with grounding because they have proven to [to me] smoothen out the powerband and eliminate this slight stumble, despite being on the stock ecu, new plugs, cap/rotor, valve adjustment, fuel pressure etc.etc. in check. Just changing the wires alone helped FWIW.
On the other hand, what quality wires like the power cables will give you is a good secure fit. Unlike some of the **** (possibly older - uncertain with current generation) from Nology and MSD. Where the MSDs had to be zip tied to the cap...and the Nology's just "sat" feeling very unsecure on top of the plug.
Both of those plugwires (again, this was at LEAST 4yrs ago) caused ignition problems when they obviously were victims of poor design and engineering. What GOOD is the actual wire/cable if they don't stay in place??
Nothing fits like OEM and the NGK powercables, they literally click in place. Not even the grounded Spoon cables feel like OEM.
Old Oct 15, 2006 | 12:52 AM
srd....'s Avatar
Dragon Slayer For Hire
Default Re:
Nology HotWires
ive red ones but they come in five or more differant colours...if colour is an issue for ya.
95civicB16
Jul 14, 2007 04:06 PM
srv3fender
15
Mar 23, 2005 09:09 AM
EzKV
Mar 17, 2004 01:56 PM
wannakno
Nov 26, 2002 08:32 PM
KF_S2000
Feb 2, 2002 06:08 PM
