94 RS with big problems
I have a 94 Integra RS, all stock. The problem is that my 3 and 4 pistons are not firing. The plugs are sparking and the 1 and 2 are just fine. I have replaced the fuel injectors, but that didn't help. I also did a compression test and it was good. Any ideas?
Well it is either not getting fuel or not getting spark, or not getting both of them at the correct time because if it is getting both of them at the correct time it will fire, so the only thing i know to tell you is to check the timing.
civicwagonman
Nov 30, 2002 11:15 AM
