GSR swap into 93 ex 4dr
Old Oct 12, 2006 | 08:51 AM
Timberland237's Avatar
Default GSR swap into 93 ex 4dr
I was wondering what i need to do for the wiring i have the whole swap kit, liek mounts engine tranny axles etc and was wondering if i just remove my wiring harness and put the gsr's. if you want to see where i'm at go here http://www.piczo.com/civicswap i will post new pics everyweek thanks in advance.
Old Oct 12, 2006 | 08:56 AM
RTD Autoworks's Avatar
Default Re: GSR swap into 93 ex 4dr (Timberland237)
if you swaping odb1 gsr motor in the ex wire harness should work fine just need to extend out a couple of wires but other then that should work fine
Old Oct 12, 2006 | 09:02 AM
Kruzen510's Avatar
Default Re: GSR swap into 93 ex 4dr (RTD Autoworks)
Yeah, your stock harness will work fine once you extend some wires. the only thing you'll have to wire in, is your knock sensor.
Old Oct 12, 2006 | 11:16 AM
Default Re: GSR swap into 93 ex 4dr (Kruzen510)
do you know where i can find the specs for wiring the knock sensor or maybe you know a crash course :D thanks alot for the info
ILoveJDM89
Sep 21, 2008 06:00 PM
91blksi
Feb 23, 2006 04:11 PM
platypussk8er
Nov 30, 2005 02:53 PM
oneslowsohc
Feb 15, 2005 09:35 AM
stivic
Sep 21, 2004 12:45 PM
