Where is my coolant going?
Old Oct 12, 2006 | 08:16 AM
BLUE EH3's Avatar
Help we my pennies
Default Where is my coolant going?
I looked in my coolant res bottle and it was empty, so i filled it up, and checked it a few days and it was empty again.. wher is the coolant going?
Im not over heating, so whats the deal? i also have no cat
Modified by BLUE EH3 at 8:15 PM 10/21/2006
Old Oct 12, 2006 | 08:20 AM
ChinitodeNJ's Avatar
Default Re: Where is my coolant going? (BLUE EH3)
check for any leaks in the hoses
Old Oct 12, 2006 | 08:22 AM
1baddcivicsi's Avatar
Default Re: Where is my coolant going? (ChinitodeNJ)
if the coolant disappears it could be a leaky headgasket. i had this problem on one of my cars last year and i couldnt fiqure-out where the coolant was going.
Old Oct 12, 2006 | 09:01 AM
DragWerks's Avatar
Default Re: Where is my coolant going? (1baddcivicsi)
Does the car run hot? Check around water pump and hoses in back of the motor
Old Oct 12, 2006 | 12:32 PM
Sloshy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote"> I looked in my coolant res bottle and it was empty, so i filled it up, and checked it a few days and it was empty again.. wher is the coolant going?
Im not over heating, so whats the deal?</TD></TR></TABLE>
THATS THE SAME THING WITH MY CAR!!! i have know idea what it is but today im gonna go buy the leak detector and see if theres a leak... this happen after my car over heated due to a sticking thermostat so it might be the head gasket hopefully it isnt , dont feel like taking it apart..
Old Oct 12, 2006 | 08:31 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Where is my coolant going? (hatch-E-vanish)
i guess i gotta check for leaks, whats the bestway to check?
Old Oct 12, 2006 | 08:32 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Where is my coolant going? (DragWerks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragWerks &raquo;</TD></TR><TR><TD CLASS="quote">Does the car run hot? Check around water pump and hoses in back of the motor</TD></TR></TABLE> car does NOT run hot
Old Oct 13, 2006 | 04:02 AM
BLUE EH3's Avatar
Help we my pennies
bottle is empty again at 10/123/06 8am.. wtf??
Old Oct 13, 2006 | 11:04 AM
sql_civic's Avatar
Check for puddles under your car or wet spots underneath your hose connections.
Have someone drive behind you while you step on it. Look for white smoke to indicate a blown head gasket.
Old Oct 13, 2006 | 04:54 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Where is my coolant going? (sql_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sql_civic &raquo;</TD></TR><TR><TD CLASS="quote">Check for puddles under your car or wet spots underneath your hose connections.
Have someone drive behind you while you step on it. Look for white smoke to indicate a blown head gasket.</TD></TR></TABLE> will check
Old Oct 13, 2006 | 05:14 PM
97civicdx's Avatar
Does you car smell like syrup?
Old Oct 13, 2006 | 05:50 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Where is my coolant going? (97civicdx)
No. me and boys think its a lose upper rd hose
Old Oct 13, 2006 | 06:05 PM
97civicdx's Avatar
Dont you see any coolant leaking from any of the hoses, etc?
Old Oct 13, 2006 | 06:46 PM
dmotoguy's Avatar
my car didnt run hot with a leaky head gasket... even though it was burning off a lot of coolant.
Old Oct 13, 2006 | 06:48 PM
1lowsol2's Avatar
okay i had the same problem a year ago with my sol. I put a new thermastat in it and i havent put coolant in it since.
Old Oct 14, 2006 | 05:29 AM
vahonda97's Avatar
mine is doing the same thing. check the water pump.. cuz it should be leaking some down by the alternator , and timing belt.. look and see if any fluid is down by there..
Old Oct 21, 2006 | 04:10 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (vahonda97)
i goingto buy some of that dye next pay check..... i also have whitesmoke at start up, is that normal for hondas?
Old Oct 21, 2006 | 04:15 PM
Striker_1818's Avatar
Default Re: (BLUE EH3)
check the timing belt too...
coolant can damage it and cause it to crack.
Old Oct 21, 2006 | 04:54 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (Striker_1818)
thanks . will do
Old Oct 21, 2006 | 08:24 PM
jmezz's Avatar
Be aware of the white smoke... Dissapearing coolant is either a leak or a head gasket..
Old Oct 21, 2006 | 08:25 PM
jmezz's Avatar
I also have the same problem, only with the oil.. It takes about a quart a month..But yet I have no oil spots??
Old Oct 21, 2006 | 08:34 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Where is my coolant going? (jmezz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmezz &raquo;</TD></TR><TR><TD CLASS="quote">Be aware of the white smoke... Dissapearing coolant is either a leak or a head gasket..</TD></TR></TABLE> I had white smoke at start up, then i drove it 1 mile with the heat on and the white smoke was gone
Old Oct 22, 2006 | 12:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmezz &raquo;</TD></TR><TR><TD CLASS="quote">I also have the same problem, only with the oil.. It takes about a quart a month..But yet I have no oil spots??</TD></TR></TABLE>
check your distributor...
if it gets oil inside of it then your o-ring needs to be replaced...
Edit: should have quoted sorry...
Modified by Striker_1818 at 10:16 AM 10/22/2006
Old Oct 22, 2006 | 05:30 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: Where is my coolant going? (Striker_1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Striker_1818 &raquo;</TD></TR><TR><TD CLASS="quote">check your distributor...
if it gets oil inside of it then your o-ring needs to be replaced...</TD></TR></TABLE> i def have bad vavlue cover gsket. im bsing about fixin it
Old Oct 22, 2006 | 06:18 AM
Syndacate's Avatar
It sounds like your head or valve cover gasket.
They're both relatively easy to change, change 'em, see where you are from there.
