b16 timing belt teeth count
Old Oct 11, 2006 | 11:07 PM
mikey8422's Avatar
Default b16 timing belt teeth count
So i was doing my timing belt, everything set at TDC during removal of old belt, everything lined up putting on my new belt, cranked the motor 1 rotation, lined up the cam gears, and noticed my crank TDC was off a tooth, so i took off new belt and counted teeth, apparently the 99-00 civic si has 125 teeth, and my old belt has 124, its a jdm b16, DO i need the p30 instead of the P2T? can the teeth count be confirmed?
Old Oct 11, 2006 | 11:20 PM
Frozen E's Avatar
H-T White Ops
Can't make up for that extra tooth by tightening the tensioner a bit more?
Old Oct 11, 2006 | 11:25 PM
mikey8422's Avatar
Default Re: (IslandSi)
nope, i tried to reduce the slack as much as i could but it would just flap, it sounded horrible, like really loud valve tick, i put my old one back on and its so quiet..that extra tooth makes a big difference...
My 124toothed belt is stamped (124RU26), and the 125tooth i was sent is stamped (12418H).....but it says p2t on the plastic bag it came in. Does anyone know what the 12418H is?
Modified by mikey8422 at 1:01 AM 10/12/2006
Old Oct 12, 2006 | 06:07 AM
Sloshy's Avatar
what water pump are you using?
Old Oct 12, 2006 | 08:10 AM
CardDealer's Avatar
Banned
Default Re: (hatch-E-vanish)
Scratch that....i now see you said JDM...have no idea.
Old Oct 12, 2006 | 11:35 AM
mikey8422's Avatar
Default Re: (schlit)
im using the b16a waterpump, i found my problem i believe, i think my crank moved a tooth when installing the belt, but didnt notice it till after i took the belt back off, so im gonna redo the timing belt for the 3rd time and see what happens, woohoo! will keep an update..
Old Oct 13, 2006 | 12:39 AM
mikey8422's Avatar
Default Re: (mikey8422)
well, i got it, both belts are 124, installed belt again, paying better attention to the crank line up, i guess it did jump a tooth when i was puttin the new belt on and didnt realize..all is well! Thanks for replies!
RanCRX
Jun 1, 2014 01:41 PM
onesloweg
Mar 28, 2007 08:20 AM
onesloweg
Mar 28, 2007 02:41 AM
civic_hatchback
Jun 10, 2004 10:23 PM
eddiecut
Jun 16, 2003 12:10 PM
