cooling fan wont turn on
ok...easy to check the fan motor unplug it and stick a wire on each prong and put them on the battery terminals...if it turns on its fine...the other could be the relay...follow the wires from the plg to the replay, follow the manuals directions on how to tes the relay...then finally the sensor for the fan...OBD0 motors it on the back of the block kinda of near the oil filter and on OBD1+ motors its on the thermostat housing...make sure the plug is connected and the wires look ok...its a very simple system it works on its own without the ECU being involved so its any of the following:
Bad Fan Motor
Bad Relay
Bad Sensor
Bad Wiring
Bad Fan Motor
Bad Relay
Bad Sensor
Bad Wiring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">ok...easy to check the fan motor unplug it and stick a wire on each prong and put them on the battery terminals...if it turns on its fine...the other could be the relay...follow the wires from the plg to the replay, follow the manuals directions on how to tes the relay...then finally the sensor for the fan...OBD0 motors it on the back of the block kinda of near the oil filter and on OBD1+ motors its on the thermostat housing...make sure the plug is connected and the wires look ok...its a very simple system it works on its own without the ECU being involved so its any of the following:
Bad Fan Motor
Bad Relay
Bad Sensor
Bad Wiring</TD></TR></TABLE>
x2
Bad Fan Motor
Bad Relay
Bad Sensor
x2
tunerEF9
Apr 30, 2010 11:12 AM
