Bored and stroked
all you need is a gsr, ls crank with rods if you want to go 1.8l( will cost you less than the spoon strocker kit)
you can also sleeve the block to 84,85mm for a 2.0l set up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">all you need is a gsr, ls crank with rods if you want to go 1.8l( will cost you less than the spoon strocker kit)
you can also sleeve the block to 84,85mm for a 2.0l set up.</TD></TR></TABLE>
You can bore a B16 out to a 2.0?
I can't say I knew that O.o
Cool.
Cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
Cool.</TD></TR></TABLE>
notice how he said "sleeve the block to 84mm,85mm" i dont thing you can do that on stock sleeves, but drop-in sleeves, like benson, GE, darton etc, are all good.
DC2#309
10
Aug 26, 2004 01:43 AM
b16ferio
47
Jun 20, 2004 09:43 PM
