question about thermostat temp?
Old Oct 11, 2006 | 03:46 PM
ablack934doorcivic's Avatar
Default question about thermostat temp?
my 94 civic ex just starting doing this when i drive the temp goes way down like just about the cold mark but it still blows hot air like a motherf*#$er. then goes to normal after i sit and idle for a while. never did this before what could cause this? maybe a bad coolant temp sensor. my fluid level is fine and no air in the system. thanks for the help.
Old Oct 12, 2006 | 02:11 PM
Default Re: question about thermostat temp? (ablack934doorcivic)
anyone
Old Oct 12, 2006 | 02:25 PM
sosnowchik's Avatar
check your radiator and fluid make sure there are no cracks in it make sure your radiator fan comes on if it doesnt that means your relay switch is bad check your fuses check your thermostat and check your water pump this is all i know what to check for because my temp gauge would go up and down and i had a bad thermostat so good luck dude
Old Oct 13, 2006 | 04:26 PM
Default Re: question about thermostat temp? (sosnowchik)
thanks checked all but the thermostat. i will replace that. once again thanks for the help
Old Oct 13, 2006 | 04:43 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ablack934doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">thanks checked all but the thermostat. i will replace that. once again thanks for the help</TD></TR></TABLE>
Just got done with mine. Had the same problem but not anymore
nonhondaman
Apr 17, 2007 07:26 PM
KB96VTEC
May 23, 2005 06:30 PM
RedHB..D15B
Apr 19, 2004 12:06 PM
spoonfed95
Jun 5, 2003 09:31 PM
spart
Feb 27, 2002 04:07 PM
