93 del sol with a 93 b18 swap wont start but cranks over
this car run good i parked it and it will not start but it will crank over i checked for a spark and it do's not have one it also do's not have fuel i checked all the fuses and thay are all good i have checked the wires and thay are all pluged in.
....................... need help thanks.........................
The main relay in the underhood fuse box controls both the distributor and fuel pump, you might try checking that. It's a big *** fuse....
Hope that helps.
Hope that helps.
Neds93delsol1.6
Jul 15, 2017 08:25 AM
AaronGeisinger
Dec 11, 2010 05:15 AM
