Transmission Fluid
I have a 95 ex coupe, i changed my cv's out and was looking in my Haynes repair manual, and noticed theyre pouring 5w30 motor oil in the car, they used to write the manual. So i went and got Quaker state High RPM synthetic blend, 10W40 this alright to use?
i use gm syncromesh....u can get it from the dealer, or u can get them from autozone... it is made by pennzoil. helps reduce grinding at high rpm
at the dealer they have the one with friction modifier and regular...... autozone has the reg stuff in a yellow bottle, by the gear oils
I pennzoil makes the stuff for GM.... the weight is like 75w ish gear oil ... which is the same viscosity as 10-30w motor oil
the bottle has no weight on it
YES viscosity and weight are 2 different things
http://www.experimentalhelo.co...T.htm
Modified by cueballsi at 4:57 PM 10/11/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic995 »</TD></TR><TR><TD CLASS="quote">no pennzoil fer me. Junk oil
try reading his post correctly next time. he gave you completley true advice and facts in his post. and if pennzoil is "junk oil" to you then why are they making it for a huge automobile company??? try thinking next time.
</TD></TR></TABLE>try reading his post correctly next time. he gave you completley true advice and facts in his post. and if pennzoil is "junk oil" to you then why are they making it for a huge automobile company??? try thinking next time.
No, it's not. Pennzoil Synchromesh, along with GM Synchromesh and genuine Honda MTF, are some of the most widely used and recommend fluids for Honda transmissions here on Honda-Tech. You asked a question, and cueballsi gave you an informed reply. Don't use the 10W-40 in your transmission. Stick with one of the three listed above.
</TD></TR></TABLE>No, it's not. Pennzoil Synchromesh, along with GM Synchromesh and genuine Honda MTF, are some of the most widely used and recommend fluids for Honda transmissions here on Honda-Tech. You asked a question, and cueballsi gave you an informed reply. Don't use the 10W-40 in your transmission. Stick with one of the three listed above.
Pennzoil oils, are full of parafin waxes' that arent good for the motor as so ive heard from many mechanics; I was also told by a poster in this thread that Quaker State is also, so im dumping that **** for oil. Im gonna try the syncromesh
Thanks guys
Edit : I searched and checked the FAQ's also before i posted this
Nothing was available
Thanks guys Edit : I searched and checked the FAQ's also before i posted this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic995 »</TD></TR><TR><TD CLASS="quote">Pennzoil oils, are full of parafin waxes' that arent good for the motor as so ive heard from many mechanics; I was also told by a poster in this thread that Quaker State is also, so im dumping that **** for oil. Im gonna try the syncromesh
Thanks guys
Nothing was available</TD></TR></TABLE>
I doubt that. Try clicking the archive button and then click search.
Nothing was available</TD></TR></TABLE>I doubt that. Try clicking the archive button and then click search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnecon2001 »</TD></TR><TR><TD CLASS="quote">
I doubt that. Try clicking the archive button and then click search.</TD></TR></TABLE>
No really search syncromesh... i really didn;t find anything... kinda interes
ting
ting
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic995 »</TD></TR><TR><TD CLASS="quote">I have a 95 ex coupe, i changed my cv's out and was looking in my Haynes repair manual, and noticed theyre pouring 5w30 motor oil in the car, they used to write the manual. So i went and got Quaker state High RPM synthetic blend, 10W40 this alright to use?</TD></TR></TABLE>
If they were putting in 5W30, what made you go out and get 10W40? My buddies and I use Honda MTF.
I use MTF, no issues there. (well I assume its the same blend, I actually use the acura stuff) They just changed the fluid to a newe "improved" blend, at least acura did. It was purple! They claim better fuel economy and smoother shifting. Whatever, as long as its Honda and works.
acura, autozone, fluid, friction, gm, honda, issues, modifier, mtf, pennzoil, scottsdale, synchromesh, transmission
