Water injection on an N/A motor
Old Oct 11, 2006 | 02:49 PM
2wheelhunter's Avatar
Default Water injection on an N/A motor
would a water injection system benefit a N/A engine at all?... i understand the system and how it makes the air more dense decreaseing the amount of octane the engine needs under a load, but i was wondering if hp or tq numbers would change at all when an h2o injection system was used on an all motor car.
Old Oct 12, 2006 | 07:41 AM
Default Re: Water injection on an N/A motor (2wheelhunter)
bump
Old Oct 12, 2006 | 07:44 AM
schardbody's Avatar
maybe in one scenario, ULTRA HIGH COMPRESSION where the combustion temps are TERRIBLY high and timing is dropped. the h2o injection might help lower the combustion temps and allow for more timing w/out detonation, but thats the only way i can see if helping a N/A build at all.
not worth it really.
Old Oct 12, 2006 | 09:02 AM
DragWerks's Avatar
Nope, will only hurt...
Old Oct 12, 2006 | 09:04 AM
Kruzen510's Avatar
Default Re: (schardbody)
probably won't see a gain unless you go turbo/supercharger
Old Oct 12, 2006 | 09:08 AM
kiddcarbuff's Avatar
thats odd, my buddy has a b16a2, somewhat built head and he has water methonal injection and it made some more horsepower and torque thru the powerband, but he timing its retared like 20 degrees
Old Oct 12, 2006 | 09:12 AM
Kruzen510's Avatar
Default Re: (kiddcarbuff)
you really should be tuned for it, for it to help you out. your n/a intake temps aren't going to get high enough for you to really need it though. this is what i've been told from a couple of people that have installed it on their cars and played around with it.
Old Oct 12, 2006 | 04:57 PM
schardbody's Avatar
Default Re: (Kruzen510)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kruzen510 &raquo;</TD></TR><TR><TD CLASS="quote">you really should be tuned for it, for it to help you out. your n/a intake temps aren't going to get high enough for you to really need it though. this is what i've been told from a couple of people that have installed it on their cars and played around with it.</TD></TR></TABLE>
exactly.
The_Godfather
Nov 9, 2012 12:45 AM
cvelazquez
Apr 26, 2012 04:28 PM
jetlude
Feb 1, 2007 05:24 AM
comptechgsr
Sep 20, 2002 11:51 AM
ck279
Jun 7, 2002 07:23 AM
