Higher Compression With Metal Head Gasket?
Old Oct 11, 2006 | 12:40 PM
89D15CRXDX's Avatar
Default Higher Compression With Metal Head Gasket?
I recently bought a metal head gasket as I'm building a D15B2/D16A6 hybrid and I heard that I can up the compression for more HP by removing the middle layer of the three layer head gasket. Is this true? If so, what kind of CR and HP increase can I expect?
Old Oct 11, 2006 | 12:46 PM
4dOoR-Ex's Avatar
hurd the same thing....any one out ther noe about this..?!
Old Oct 11, 2006 | 01:29 PM
89D15CRXDX's Avatar
Default Re: Higher Compression With Metal Head Gasket? (89D15CRXDX)
Well, this is obvious because the less space there is between the head and block, the higher the CR. Thinner head gasket, high CR pistons, milling the head, many different factors can raise the CR effectively. But even at 12.0:1 you would only recieve an increase of about 7.9% of your current HP. But with this CR, you would have to run 93 octane fuel just to compensate. But obviously this is only for running a naturally aspirated setup. With forced induction, a lower CR is desired to reduce the chance of detonation. I ran a B18A1 at the stock CR because it was the perfect platform for turbo. T3/T04e .63/.60 ran my stock internal motor to pull a 247HP dyno run. Of course my 92 Integra GS ran many other aftermarket parts to achieve this. But I was just wondering HOW dissasembling the head gasket would help. Now I see.
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
BAZ
May 5, 2003 06:49 PM
Evs-One
Mar 3, 2003 01:09 AM
you2envious
May 26, 2002 06:26 PM
B18CRacer
Jan 29, 2002 11:39 AM
