What should i do?
Ok so i just purchased this car,what should i do with it?I can spend $1000 on it right now,its a civic dx 93 here are some pics:
I got it for $1995 with 125,578 miles on it and it has a dent in the hatch,no right mirror, a little rust, and no rear speakers
What should i do with the money? ($1,000)
New engine?which?
Modified by Felliph3 at 4:33 PM 10/11/2006
New engine?which?
just a FYI: before you paint it, you are going to HAVE to fix the dnts and the rust, or else its just going to like ***, only shinier. Secondly, 2 grand isnt that bad of a price I guess. If I were you, I would take that 1000 you have, and do some general maintnence on it. like changing timing belt/ water pump, etc. and for future refernce, dont start thread with titles like, what should I do next, and to post picture threads, do it in the A/C forum. Have fun, and welcome to H-T
damn bro...i can see there are still some pretty clean EG's out there haha...sweet buy man...first things first...i would get some nice 15 rims oem/rota/volks/konig/ etc...and then choose some good grade tires...i would recommend the yoko avs es100's 205/50/15's...i have them and they stick pretty well...second step get some better rotors and pads...i'd recommend hawk pads with brembo blanks...start from bottom up bro...3rd step would be suspension....Ground controls and kyb adj...best bang for the buck...good luck on your build man...o .and plz...get some security...dont go cheap...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">damn bro...i can see there are still some pretty clean EG's out there haha...sweet buy man...first things first...i would get some nice 15 rims oem/rota/volks/konig/ etc...and then choose some good grade tires...i would recommend the yoko avs es100's 205/50/15's...i have them and they stick pretty well...second step get some better rotors and pads...i'd recommend hawk pads with brembo blanks...start from bottom up bro...3rd step would be suspension....Ground controls and kyb adj...best bang for the buck...good luck on your build man...o .and plz...get some security...dont go cheap...</TD></TR></TABLE>
you just used the word rota, and volk in the same sentence...
HAHA, BIG difference
Good advice.
Good advice.
get yourself a pieced together turbo kit! I'm in the process of making my own and so far the projected total WITH tuning is 1350. also if you decide to do a d16z6 swap or a b seires...a majority of the parts will be reusable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">if you're smart you'd upgrade the suspension first.
but if you're like most kids you'll buy some goofy rims or some giant stereo system.
we'll see.</TD></TR></TABLE>
Whats the deal with the suspension?I WILL NOT CUT THE SPRINGS!I will get some shocks or adjustables or whatever but i wont cut them ,that is rice! Why should i upgrade the suspension first? Snow is coming up too so i cant have it too low, i need adjustables.Do the OEM ones go bad?
I think you should set it on fire. FIRE! FIRE!
That would cost way less than $1000, and it would look really badass, for a while anyway.
Other than that, I can't see getting a good paint job with the body work for $1K, or a decent swap for that little $. You could get wheels/tires, but why bother on a stock DX with minor cosmetic flaws. Personally I'd turbo it. I just got a rebuilt 2G DSM T25 -w- internal WG, O2 housing, and a decent TIG-welded SS log manifold off of ebay for $200. People sell chipping kits for your OBD1 ECU for about $20, and if you can't solder they'll install the kit for a few more $. I need to order a $10 downpipe flange and pay my local welder to weld a $2 slip-fit exhaust coupler to it, then I just put a $1 clamp on it and there's plenty left out of $1K for a set of injectors and resistor box (if you get low impedance injectors), cheap ebay charge piping and IC, and an hour or two of dyno tuning with a WB.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels »</TD></TR><TR><TD CLASS="quote">I think you should set it on fire. FIRE! FIRE!
Found a turbo for 300 plus 40 shipping,good?
http://cgi.ebay.com/ebaymotors...QrdZ1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felliph3 »</TD></TR><TR><TD CLASS="quote">Found a turbo for 300 plus 40 shipping,good?
http://cgi.ebay.com/ebaymotors...QrdZ1 </TD></TR></TABLE>
a t3/t4 turbo alone costs about 300...let alone the full kit...i call bs on that auction...doesnt seem legit. plus a t3/t4 turbo is pretty big for a stock d15.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard »</TD></TR><TR><TD CLASS="quote">
a t3/t4 turbo alone costs about 300...let alone the full kit...i call bs on that auction...doesnt seem legit. plus a t3/t4 turbo is pretty big for a stock d15.</TD></TR></TABLE>
Thought so too,it would maybe fully spool by 5th,never by the lower gears.
Doesn't look like it's AC/PS compatibl;e, but that's a great price. The only thing I'd worry about is the turbo, could be too big for an SOHC motor causing lots of lag, and it may need to be rebuilt, even if it does...get that kit, sell the turbo(if it's too big or needs a rebuild, otherwise keep it if it's fine) and tune it, even if you used the buy it now price you should be able to get it tuned and your oil pan fixed up for the drain line for under 1100 out the door.
Truth^^
It will sell for way more then 300 too.
Like rmcdaniels said, Piece together a turbo kit for the car and DIY.
Truth^^
suspension. this means replacing all worn bushings, ball joints, inner and outter tie rods, upgrading shocks, springs, alignment, wheels and tires. should cost you around 1200 if youre pretty handy and do a lot of the work yourself.
then brakes. i'd buy new calipers up front, new wheel cylinders out back, fresh drums and discs for the front, and new lines, fluid and pad compound. Also replace the master cylinder. and think about doing the front wheel bearings and hubs too.
the seller wants $800 buy it now, so im going to guess that he wouldnt let it go for $300. he either has a reserve set or a price in mind that he will sell it for.
Im not going to make a sleeper,i need to take care of looks first.All show no go is not what i have in mind,i need rims and a bodykit in a while but rims is a must,i cant ride 13's! Too embarassing. I also need a tach but should i get one or just get an SIR II gauge cluster? So rims is a must and some power.
That looks decent to me, but at $300 the reserve isn't met, so how much does he really want for it? It also says it comes with an "ECU chip", whatever that means, is he also including a chipped ECU? I don't see any injectors with it, which should be there if the ECU is chipped. It's an old Drag manifold and he doesn't say what type of turbo is it (cheap Chinese XS Power junk or a decent turbo?), plus no IC and a $20 old DSM BOV. I was thinking more along the lines of something I bought recently for a B-series:
http://cgi.ebay.com/ebaymotors...&rd=1
Intercooler with piping for $19 shipped:
DSM 450 injectors, $70 shipped:
Resistor box for injectors, $15.50 shipped:
etc, etc, etc.
etc, etc, etc.
