I need someone to help me with my 90 Integra's idle/rpm problem
Old Oct 11, 2006 | 07:25 AM
Dforce's Avatar
That's what she said!
Default I need someone to help me with my 90 Integra's idle/rpm problem
I already searched and tried what I could to fix the idle/rpm problem. So I need someone that knows alot about DA's with b16's and could help me with this problem.
Basically when i start the car up in the morning, the rpm goes up and down, once the car is warmed up it idles below 500 rpm. Sometimes while at a stop light it drops below 500 and wants to shut off.
I don't want to take it to a shop, I know someone out there wants to make some money! I can't offer much! let me know. Thanks.
Old Oct 11, 2006 | 08:23 AM
loopedR6's Avatar
Default Re: I need someone to help me with my 90 Integra's idle/rpm problem (Dforce)
its your IACV
go here to figure out how to clean it.
https://honda-tech.com/zerothread?id=1575913
Old Oct 11, 2006 | 08:29 AM
Dforce's Avatar
Default Re: I need someone to help me with my 90 Integra's idle/rpm problem (loopedR6)
I bought the car with the B16 in it and it came with a skunk2 intake manifold. Would the IACV still be on it?
BTW it's my girlfriend's car so I can't go out and check right now.
Old Oct 11, 2006 | 07:49 PM
Dforce's Avatar
bump.
Old Oct 11, 2006 | 07:52 PM
Lavisracing's Avatar
check the connections of the ign. coil in the dizzy
Old Oct 11, 2006 | 08:14 PM
Dforce's Avatar
Default Re: I need someone to help me with my 90 Integra's idle/rpm problem (Lavisracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lavisracing &raquo;</TD></TR><TR><TD CLASS="quote">check the connections of the ign. coil in the dizzy</TD></TR></TABLE>
will do!
Old Oct 11, 2006 | 08:15 PM
thats what was up with mine if they are weak or loose it will foul like that
Old Oct 11, 2006 | 08:25 PM
Dforce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lavisracing &raquo;</TD></TR><TR><TD CLASS="quote">thats what was up with mine if they are weak or loose it will foul like that</TD></TR></TABLE>
so if it's weak or loose should i replace?
Old Oct 11, 2006 | 08:28 PM
no dont replace them just take light sandpaper to the wires and contact points then a little electrical gel and then make them tight.
Old Oct 11, 2006 | 08:32 PM
Dforce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lavisracing &raquo;</TD></TR><TR><TD CLASS="quote">no dont replace them just take light sandpaper to the wires and contact points then a little electrical gel and then make them tight.</TD></TR></TABLE>
sounds good! thanks!
1.5 ef
May 25, 2013 06:11 AM
samdizzle562
May 30, 2007 12:21 PM
Shmolie
Jun 29, 2005 05:58 PM
TypeRPaul
May 21, 2004 05:43 PM
HaUTSaauce
Mar 30, 2003 04:12 PM
