buddy club headgasket
Old Oct 10, 2006 | 08:16 PM
L_K's Avatar
L_K
Default buddy club headgasket and question about pistons?
have anybody try the headgasket made by buddyclub?
http://www.inlinefour.com/budclubracsp4.html
how are they compare to the mugen or spoon headgasket if i want to raise my compression? also, wat piston should i use if i want to raise my compression in my C5?
Modified by L_K at 9:38 PM 10/10/2006
Old Oct 11, 2006 | 09:00 AM
BoBo Racing's Avatar
Default Re: buddy club headgasket and question about pistons? (L_K)
I've used it, and no complaints about it. You can just buy a OEM head gasket and make it a two layer also, by taking out the middle layer of the gasket. Same thing as the buddy club.
Modified by BoBo Racing at 2:05 PM 10/11/2006
Old Oct 11, 2006 | 09:43 AM
realis9's Avatar
taking about the middle layer is that safe? How do you get the other two ends to stick together copper spray?
Old Oct 11, 2006 | 10:01 AM
heel_touge's Avatar
Default Re: buddy club headgasket and question about pistons? (realis9)
OEM>all others
Old Oct 11, 2006 | 10:21 AM
L_K's Avatar
L_K
Default Re: buddy club headgasket and question about pistons? (1slowcivic)
I heard alot of people say that OEM > aftermarket, so if i want to raise my compression, should i just use different piston? like a oversize .25mm from a b16b?
Old Oct 11, 2006 | 01:17 PM
yea that would help out if you do. the buddy club head gasket only you only raise ur compression to 10:8:1 if you want to experiment and see what compression you will get, heres a link.
http://www.c-speedracing.com/h...c.php
Old Oct 11, 2006 | 03:01 PM
L_K's Avatar
L_K
Default Re: buddy club headgasket and question about pistons? (BoBo Racing)
thx so much!!
Old Oct 11, 2006 | 03:54 PM
GUILOTINE's Avatar
Kill Gil
Im using it and it works great
Old Oct 12, 2006 | 12:53 PM
realis9's Avatar
Default Re: buddy club headgasket and question about pistons? (GUILOTINE)
but u know that if you use thiner headgasket when you do the timing belt and camgear aligning gonna be harder cuz it will be off like the TDC
Modified by realis9 at 5:52 PM 10/12/2006
Old Oct 12, 2006 | 01:37 PM
GUILOTINE's Avatar
Kill Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">but u know that if you use thiner headgasket when you do the timing belt and camgear aligning gonna be harder cuz it will be off like the TDC
nothing tuning can't easily fix
Old Oct 12, 2006 | 02:53 PM
realis9's Avatar
^ what about when it's time to do a valve adjustment?
Old Oct 13, 2006 | 07:35 AM
LUCKY CHARMS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">^ what about when it's time to do a valve adjustment?</TD></TR></TABLE>
please elaborate,
i've got Buddy Club 3+ cams, valves ,pulleys bought for my '97 jdm itr. i also purchased the buddy club head gasket to raise my compression a bit, i'm just waiting on arp head bolts to arrive & i intend starting the build.
i've searched this subject quite a bit, CTR pistons would raise my compression too much for daily driving (irish octane is 95) so the thinner head gasket was my best option,i assumed valve adjustment and the tensioner would compensate for the thinner gasket????
Old Oct 13, 2006 | 09:03 AM
ITRnorway's Avatar
or do a valve timing check. that would solve everything
Old Oct 13, 2006 | 09:09 AM
Default Re: (ITRnorway)
could u elaborate please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRnorway &raquo;</TD></TR><TR><TD CLASS="quote">or do a valve timing check. that would solve everything</TD></TR></TABLE>
what is that? what do u mean? a valve adjumtent? could u please explain as well?
Old Oct 13, 2006 | 11:45 AM
i thought it was .007intake and .008 exhaust
Old Oct 13, 2006 | 03:16 PM
GUILOTINE's Avatar
Kill Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBo Racing &raquo;</TD></TR><TR><TD CLASS="quote">i thought it was .007intake and .008 exhaust</TD></TR></TABLE>
you are correct
Blue94Accord
Oct 23, 2010 04:00 PM
tomlinson619
May 26, 2006 08:01 AM
xyzalvarez
31
Sep 5, 2005 09:54 AM
infra
Aug 6, 2004 11:43 AM
tek_civic
Nov 8, 2002 10:52 AM
