VTEC PROBLEMS (YES I SEARCHED)
Old Oct 10, 2006 | 04:24 PM
ls1tjw's Avatar
Default VTEC PROBLEMS (YES I SEARCHED)
VTEC DOES NOT ENGAGE AT ALL. THE OIL PRESS SWITCH AND SOLENOID HAVE BEEN REPLACED AND THE VALVE BODY HAS BEEN CLEANED THOROUGHLY. ALL WIRES FROM ECU HAVE BEEN TESTED AND ARE GOOD. THERES NO AND I MEAN 0 OIL PRESSURE AT THE TEST PORT ON THE HEAD AT ANY RPM . I AM LOST HAS ANY ONE HAD ANY SIMILIAR PROBLEMS ? OR SOMETHING ELSE TO TEST.
Old Oct 10, 2006 | 04:28 PM
Revi's Avatar
Default Re: VTEC PROBLEMS (ls1tjw)
If you are getting 0 oil pressure at the head, i suggest you take a look at your oil pump. Sounds like it took a dump.
Old Oct 10, 2006 | 04:47 PM
ls1tjw's Avatar
Default Re: VTEC PROBLEMS (Revi-Ra)
THE OIL PUMP IS BRAND NEW AND I HAVE PLENTY OF OIL PRESSURE AT THE BLOCK.
Old Oct 10, 2006 | 04:52 PM
WhiteBB2's Avatar
I dont know the answer to your question, But there is a caps lock button on a keyboard for a reason!
Old Oct 10, 2006 | 04:57 PM
.BigSexy's Avatar
most hood white kid
Default Re: VTEC PROBLEMS (WhiteBB2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteBB2 &raquo;</TD></TR><TR><TD CLASS="quote">I dont know the answer to your question, But there is a caps lock button on a keyboard for a reason!</TD></TR></TABLE>
for real...lol
so you are getting pressure to the block, but not to the head?? am I getting you correct? this may sound dumb, but is the ground on the OPS secured to a good ground on the chassis?
Old Oct 10, 2006 | 05:20 PM
mgags7's Avatar
<FONT SIZE="4">DID YOU REMOVE THE OIL CONTROL ORIFICE?? (IS THIS AN H23 BLOCK??)
OH AND DONT TYPE IN CAPS YOU FARKIN N00B</FONT>
tobster
Mar 13, 2011 12:32 PM
Acidcrakker
Jul 25, 2009 09:10 PM
bigmacks
Aug 11, 2005 12:48 PM
queez
Jan 3, 2005 06:12 PM
lemongreenhatch
Jun 26, 2004 07:24 AM
