CRAZY intermitent 2nd cyl misfire (srched)
Old Oct 10, 2006 | 03:38 PM
Coltmorris's Avatar
Default CRAZY intermitent 2nd cyl misfire (srched)
d16A vtec..(sohc zc) its obd1 new plugs, new wires, pretty new dizzy...a few weeks ago my car just started running on 3 cyls..at first i thought a wire popped off which has happened before, but nope all wires were on..so the next morning i started it up and it ran FINE throughout the revs for like another week, then like just randomly it would sputter and miss..then it would stop and be totally fine! now it came back and has NOT gone away..sometimes cyl 2 will not fire ..sometimes it will but after 3k revs..the car dogs and misses like crazy! checked the cap and rotor and they look great. I dont have a comp tester..but this problem is soo intermitent it doesnt seem like a bottom-half problem. No, im not running a 4-wire o2, but its been like that for a lonng time and ran super...any ideas?
Old Oct 10, 2006 | 04:08 PM
d16vtecx's Avatar
Default Re: CRAZY intermitent 2nd cyl misfire (Coltmorris)
have you checked your spark plugs
maybe a bad fuel injector
Old Oct 10, 2006 | 04:38 PM
Crx Jimmy's Avatar
bad plug wire
Old Oct 10, 2006 | 04:43 PM
Boosted Chemist's Avatar
Default Re: CRAZY intermitent 2nd cyl misfire (Crx Jimmy)
maybe a bad coil
Old Oct 10, 2006 | 05:03 PM
Coltmorris's Avatar
Default Re: CRAZY intermitent 2nd cyl misfire (Boosted Chemist)
ok...to the guys about the plugs and wires...theyre like less than 5k miles old..so you still think they could be bad? i took the 2nd cyl plug out and it look ok...how would i replace the injector? should i just replace all of them? is that a pain to do? dos this sound odd to any of you guys? like..how itll go from running on 3cyls to 4..within like 2 seconds?
Old Oct 10, 2006 | 05:25 PM
Coltmorris's Avatar
hey you guys think that because im not runing an o2..therefore running really rich that my plugs are just toast? they really dont look too fouled though yanno...ahhh help i gotta get this thing running
Old Oct 10, 2006 | 06:42 PM
Coltmorris's Avatar
ahhh last bump
Old Oct 10, 2006 | 07:08 PM
91civicEX's Avatar
howw do you know its #2?
Old Oct 10, 2006 | 07:10 PM
Coltmorris's Avatar
Default Re: CRAZY intermitent 2nd cyl misfire (91civicEX)
i pulled the plug wire out of the #2 cyl when it was running like **** and nothing changed
Old Oct 10, 2006 | 08:42 PM
Coltmorris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">maybe a bad coil</TD></TR></TABLE>
what do you mean?
Old Oct 10, 2006 | 09:08 PM
ic's Avatar
ic
coil=ignition coil
O2 would not affect just the one cylinder.
Neither would coil.
Only way I could see coil as a problem is if it's weak and the plug gap is too large on the bad cylinder.
could be sticky valve.
Some tests from quickest to most involved:
-when the engine is misfiring, check to see if the injector is working. Use a screwdriver or socket extension like a stethescope. Touch one end to the injector and put your ear to it. Check for steady ticking sound.
-try switching plug wires on the bad cylinder (don't rearrange firing order, just swap the #2 & #3 wires and see if the problem changes cylinders.)
-get a spark tester and follow directions. should produce bright white/blue spark. Not orange/yellow.
-pull all spark plugs. compare them and make sure gap is correct.
-compression test
-switch injectors around and see if the problem moves
this should get you started.
Old Oct 11, 2006 | 07:30 AM
Coltmorris's Avatar
Default Re: CRAZY intermitent 2nd cyl misfire (ic)
alright great thanks...it only does it when it heats up for some reason--i just hope its not in the valvetrain
Old Oct 11, 2006 | 10:39 AM
Coltmorris's Avatar
well i put new plugs in it...and it still runs badly...you guys have any injecter suggestions? should i upgrade to bigger ones or just get new stock ones or what
milanocivic
Feb 20, 2009 08:26 PM
IntegraType-R
Aug 24, 2007 10:14 AM
civiccpedx
10
Feb 1, 2005 02:56 PM
mongoliandonuts
13
Aug 30, 2004 10:35 PM
IamVtec
14
Apr 12, 2003 08:10 AM
