1/4 mile times?
Old May 3, 2002 | 02:05 AM
homegrown96734's Avatar
Default 1/4 mile times?
what kind of times should i be running?how can i get a good launch with a 5 speed?
Old May 3, 2002 | 05:57 AM
threatcon13's Avatar
New User
Default Re: 1/4 mile times? (homegrown96734)
with those mods and some awesome driving you should be able to net high 14s me thinks. i usually launch at around 4500...sometimes sidestepping the clutch and sometimes feathering it. im still tryin to find out what works best for me....u should do the same; just experiment
Old May 3, 2002 | 06:55 AM
neo1z's Avatar
Default Re: 1/4 mile times? (ALLMOTORDC2)
mid to high 14's
Old May 3, 2002 | 07:10 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 1/4 mile times? (neo1z)
you might be capable of low 14's if you get a 2.0 60' time or better, assuming that V-AFC is properly tuned. See my sig for my time, if I could get a sub-2 second 60' time I would be in the mid 14's, and all I have is intake, shifter, and suspension.
Old May 3, 2002 | 07:30 AM
nerdish's Avatar
Default Re: 1/4 mile times? (PatrickGSR94)
How is he supposed to get a 2.0 or less 60' time??
Old May 3, 2002 | 07:50 AM
Black SVT's Avatar
Default Re: 1/4 mile times? (nerdish)
If you take the interior out and given the vafc isn't detrimental I would say mid 14's.
Old May 3, 2002 | 08:41 AM
Community Builder
I've seen it done... traction bars helps alot but I've seen it done w/o the bars... although it may have been on some slicks or drag radials.
[Modified by PatrickGSR94, 11:41 AM 5/3/2002]
Old May 3, 2002 | 09:03 AM
jgrotkier's Avatar
I got a 14.8 with just I/H/E, I would imagine you could get better than that.
Old May 3, 2002 | 09:29 AM
SonicBlueTeg's Avatar
what kinda tires/rims are you using when u run? tire psi?
i get the best times when i launch my gsr at 4700-5000 .. 28psi 16" rims, street tires.
350znal
Mar 15, 2011 01:07 AM
Nextelbuddy
Jun 19, 2004 09:32 PM
Kermit EK
Feb 21, 2003 04:02 AM
legendboy
May 27, 2002 03:44 PM
CovertFI
May 21, 2002 03:16 PM
