Stock throttle body on SOHC vtec ?
Hi, Can I use stock CRX si Throttle body on a mini me obd1 setup (d16z6 - d16a6) ??????????????
I am using d16z6 IM
I tried to search but I didnt found anything
Modified by JUN. at 6:10 PM 10/10/2006
I am using d16z6 IM
EDIT for new info: all d series (OBD0) throttle bodies are the same bolt pattern, and the 92+ is the same as b series bolt pattern.
Modified by ham at 12:01 PM 10/11/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham »</TD></TR><TR><TD CLASS="quote">all d series throttle bodies are the same bolt pattern, except the d16y8 which is a b series bolt pattern.</TD></TR></TABLE>uhh, NO!!
0bd0 d series tbs are a bolt pattern all their own. 92+ all share the same pattern as B series.
so NO, an a6 tb will not work on a z6 IM
my z6 throttle body would not bolt onto my d16y8 manifold..... ?? but the b18 did.
i guess the big question is: why do you want to use your crx throttle body? just use all the d16z6 stuff!
o_O so does it work or not....... I dont have the d16z6 TB thats why im asking. When I bought the cylinder head, it just came with the components and the IM.... no TB
just try it, i was told this info by somebody else actually (That theyre all the same), but now that im doubted im curious.
i have a d16z6 throttle body if you need one!
thanks for the offer, but Im so poor right now since I just bought a p28 and a d16z6 distributor..... MAybe in a week or so
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. »</TD></TR><TR><TD CLASS="quote">o_O so does it work or not....... I dont have the d16z6 TB thats why im asking. When I bought the cylinder head, it just came with the components and the IM.... no TB</TD></TR></TABLE>not gonna work.
you a6 and z6 tbs are different. thats why all obd0 guys swap to a z6 IM so they can run a B-series TB. i know thats why i did it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">not gonna work.
you a6 and z6 tbs are different. thats why all obd0 guys swap to a z6 IM so they can run a B-series TB. i know thats why i did it</TD></TR></TABLE>
yup.
Just wait a week and get some cash adn run to the junk yard.
yup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. »</TD></TR><TR><TD CLASS="quote">sounds good, which b18 TB is best for sohc vtec ? LS ?</TD></TR></TABLE>obd1 LS or GSR, they are both 60mm
you are going to need to port your IM a little bit to make the opening match the size of the TB
wfocrx
Sep 30, 2006 07:53 PM
