D16Z6 block, Y8 crank - possible issues?
Old Oct 10, 2006 | 12:25 PM
HiProfile's Avatar
Default D16Z6 block, Y8 crank - possible issues?
I happen to have a micropolished Y8 crank and crank-less Z6 block, I was wondering if anyone knows of issues with this combo? I would use the proper Y8 crank pulley, but I guess my main concern is if there may be some issue with the oil pump. I know the general concensus is that the Z6 oil pump has less issues than the Y8 pump, which is another reason I want to use this combo rather than hunt for a nice Z6 crank and spend more time/money on getting it micropolished.
Old Oct 10, 2006 | 01:04 PM
Bense's Avatar
Default Re: D16Z6 block, Y8 crank - possible issues? (HiProfile)
I am 99% sure that there will be no issues. Use the z6 pulley as it's timing marks are at 16BTDC whereas the y8's is 12BTDC
Old Oct 10, 2006 | 06:19 PM
HiProfile's Avatar
Default Re: D16Z6 block, Y8 crank - possible issues? (NathanMorris)
So since the crank is micropolished already, do you think it wise for me (or a motor builder) to try camfering the holes after the fact? At one of my jobs we have all sorts of methods for smoothing edges, so I wouldn't assume I'd need it polished again. I may just rip apart the bad Z6 block my other car came with and compair the undamaged part of the crank oiling holes to the Y8 crank I have.
Anyways, thanks for the info. Its been a shitty 2 weeks (crashed one car, blew up another ), so every bit helps.
AbitAvenger
Feb 22, 2012 12:35 PM
bnmm
Nov 10, 2011 11:27 AM
TheCivicMafia
May 23, 2010 08:31 PM
TylerB
Mar 28, 2009 05:52 AM
b20accord
Aug 18, 2007 06:44 PM
