Anyone knoe about d16a6 cam in d15b2 head?
There was a topic about puting a d16a6 cam and camgear on a d15b2 head both non vtec and since im going to do a timming belt and water pump changed might as well get to that. but anyways i want to see what i need to do it and is it even worth it THANKS
i think its worth it as long as you have mpfi conversion done already..if you dont and still run the stock d15b2 ecu you should leave it be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">i think its worth it as long as you have mpfi conversion done already..if you dont and still run the stock d15b2 ecu you should leave it be.</TD></TR></TABLE>
MPFI was done on Sat and its great!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 »</TD></TR><TR><TD CLASS="quote">^^Yep.
Also, you'll need a Y7/Y8 cam gear to zero the cam timing.</TD></TR></TABLE>
So any of the two? Y7 or Y8?
and im buying a d15b2 timing belt kit with water pump is that straight?
additional great info to help clarify for some
https://honda-tech.com/forums/showth...6a6+head+d15b2
hopefully it'll save someone some grief
rass1313
Mar 14, 2005 11:20 AM
slvrcivic97
Jul 28, 2003 01:32 PM
mycvc8u2
Jul 24, 2003 08:20 AM
