Do you need to change the fuse when wiring to JDM foglights for DC2?
Old Oct 10, 2006 | 10:31 AM
djdc2's Avatar
Default Do you need to change the fuse when wiring to JDM foglights for DC2?
I finally took the risk and tried wiring the high beams on my continuing project for my DC2. So now my low beam and high beams work.
But now I want to wire the fog lights and did some reading. I want the fog lights to be on when I turn on the low beams...but I read that if I do this, I'd have to swap out a fuse to a 30 amp fuse.
My question is which fuse?? I found the 2 different location for the fuse. One at next to the battery near the firewall and one under the steering wheel area. Where do I have to swap out the fuse at? WHen I bought the car it didn't come with the owners manuel so I don't know where to replace the light fuse for this. Please help.
A little more info on my car is it's a 94 RS with a conversion to a SIR-G headlights.
Old Oct 10, 2006 | 10:55 AM
Bradstard's Avatar
Default Re: Do you need to change the fuse when wiring to JDM foglights for DC2? (djdc2)
I would not wire them to come on with the low beams. I used the USDM fog light wiring harness since car had the OEM fogs when the US front was on the car. I then used the USDM switch to control the fog lights. When the car was completely gutted, I wired the relay signal to the cig lighter +12v (did not power the fogs from this, just kicked off the relay) and the fogs were basically daytime running lights at this point. Good luck, but I wouldn't wire them to my low beams.
Old Oct 10, 2006 | 05:54 PM
uNF$@#!'s Avatar
Default Re: Do you need to change the fuse when wiring to JDM foglights for DC2? (Bradstard)
i wouldnt wire them into lowbeams either.
i'd suggest using the oem fog harness for the integra.
Old Oct 10, 2006 | 07:37 PM
ITR#132's Avatar
If you want to wire them to come on with the low beams, you only use the lowbeam +12v to power the relay for the fogs (which should have its own fuse).
Old Oct 11, 2006 | 04:28 PM
djdc2's Avatar
Default Re: Do you need to change the fuse when wiring to JDM foglights for DC2? (uNF$@#!)
Now for the fog wire harness. Can you direct me to a place to get one, thanks. I already planned out where I can put the switch so it'll be easy to access and non-obscure
Old Oct 12, 2006 | 08:18 AM
jonshonda's Avatar
Community Builder
Good luck with the wiring harness. Your going to be looking for a while to find one. I would just wire the relay to the battery, switch and have the parking lights turn the relay on.
Old Oct 12, 2006 | 03:36 PM
jdmspoonitr's Avatar
Default Re: (jonshonda)
My fogs havent worked since the thieves stole my car. I really wish I could get them to turn on again....
Old Oct 12, 2006 | 05:48 PM
mugenracer's Avatar
If your going to wire them directly to the low beams then at least fit a switch (simple ground switch) on them so that you can switch them on/off when you want. I cant even remember the last time i had mine on, maybe 18months ago, i never use them!
Old Oct 14, 2006 | 01:23 PM
rucandroc's Avatar
I just went down to pep boys and bought a cheap pilot fog light wiring kit. 10 min install, fog light when ever you want them on.
Old Oct 14, 2006 | 01:38 PM
NorthernXposure's Avatar
i wired my fog lights to my highbeam swith.. i dont know about you guys.. but the factory hid's are all ill probably ever need as far as driving lights go
Old Oct 15, 2006 | 01:59 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">My fogs havent worked since the thieves stole my car. I really wish I could get them to turn on again.... </TD></TR></TABLE>
Hey if you are local hit me and we can fix that
97BB6Type-SH
Nov 24, 2008 06:46 PM
recaroem2
Honda Civic (2001 - 2005)
Nov 5, 2008 01:58 PM
Kr4nG
May 18, 2008 05:10 AM
prelude-all-the-way
Lighting
Jan 13, 2008 01:44 PM
g0tgot
Jul 4, 2007 05:03 PM
