Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
ABS light
Old Oct 10, 2006 | 06:02 AM
Sean DM's Avatar
Default ABS light
when i recently did a tranny drain n what not i refilled the tranny threw the speed sensor which caused my abs light to come on. i tryed recenting the coats
2 diffrent ways neither worked
im thinking im going to have to take it to the dealer
Old Oct 10, 2006 | 06:07 AM
Miracle's Avatar
Default Re: ABS light (Sean DM)
<U>USUALLY</U> an ABS light means that your fluid is either low in the brake cylinder, or you have a bad sensor at one of the wheels.
You will need to pull that code from the ECU to be for sure though.
Old Oct 10, 2006 | 06:10 AM
Sean DM's Avatar
i have a feeling i kow what it from lol
damn half shaft
Old Oct 10, 2006 | 06:19 AM
Miracle's Avatar
Default Re: (Sean DM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean DM &raquo;</TD></TR><TR><TD CLASS="quote">i have a feeling i kow what it from lol
damn half shaft</TD></TR></TABLE>
I don't THINK the ABS snesor goes off of the CV, I believe it goes off of the bearings. Let me go look, and I will get back with you...
CORRECTION: I went and looked, the exciter ring for the ABS sensor is on the CV shaft. Jack the car up and check to make sure they are aligned properly.
Old Oct 10, 2006 | 06:34 AM
fventura03's Avatar
mine is on because i stretched one of the lines too much when installing my coilovers... i replaced the sensor but the light is still on, i think you'll have to take it to honda to turn off, i'll do it eventually.
Old Oct 10, 2006 | 03:12 PM
Sean DM's Avatar
Default Re: (fventura03)
nvm its fixed when i got the car back today
whewww
now i just have to finish hooking up the 4 channel amp and im done!..
for a while
krazyk606
Jun 15, 2009 07:32 AM
o0Jash0o
Feb 2, 2007 10:00 AM
TypeR0186
Nov 27, 2004 10:02 PM
MF-DIF
Feb 11, 2004 05:35 PM
RyanAutry
May 3, 2003 02:23 PM
