throttle body
Old Oct 10, 2006 | 05:43 AM
snapper1978's Avatar
Default throttle body
ok when i put my car into reverse it slams into reverse from starting it when cold,if i let it warm up it will not do it so bad,someone told me the throttle body either needs to be cleaned or replaced.anyone know anything about this,had this problem,or know if i am even barkin up the right tree?
Old Oct 10, 2006 | 05:56 AM
loopedR6's Avatar
Default Re: throttle body (snapper1978)
its not your throttle body unless its running at a much higher RPM when cold. its probably your tranny, change the fluid and filter
Old Oct 10, 2006 | 07:12 AM
Default Re: throttle body (loopedR6)
when it is cold the rpms surge from bout 1 to 1.5 or 2 to 2.5,then when warm it stops
Old Oct 10, 2006 | 07:27 AM
gga_bliss's Avatar
Is your throttle body stock or modded? If it surges,
the plate might be sticking on the opening. Just clean it up with a degreaser.
Old Oct 10, 2006 | 07:35 AM
Default Re: (gga_bliss)
it is stock,do i just up bolt and clean it out,that simple,or require more?
Old Oct 10, 2006 | 08:12 AM
gga_bliss's Avatar
It's simple to clean it. Remove the intake, play with the throttle body plate. If it is sticking check inside and clean out as much you can.
Old Oct 10, 2006 | 08:26 AM
trick_db's Avatar
or could be the tb ball that is lose, need to be tighten
Type-Spaz
14
Jan 19, 2011 07:59 PM
ILS_09
Aug 31, 2009 11:21 AM
speedehatch
Jan 19, 2004 02:28 PM
NeoGSR
Feb 9, 2003 08:09 PM
vtecdc2
May 5, 2002 06:30 AM
