Can timing cause knocks in the motor
Old Oct 9, 2006 | 03:46 PM
IAWIaccord's Avatar
Default Can timing cause knocks in the motor
Is it possible to have a Knock in the motor if your timing is messed up.
1990 ex 4dr
So far i have headder and intake and have done multiple valve adjustments.
Old Oct 9, 2006 | 04:34 PM
hondadude's Avatar
Default Re: Can timing cause knocks in the motor (IAWIaccord)
If the noise is while at idle, it probably isn't the timing
Old Oct 9, 2006 | 06:22 PM
rollercosta123's Avatar
Default Re: Can timing cause knocks in the motor (hondadude)
i know what your talking about. its nothing really. just your motor running. Hows the condition of your exuahst?
Old Oct 9, 2006 | 09:04 PM
IAWIaccord's Avatar
Default Re: Can timing cause knocks in the motor (rollercosta123)
there's no holes in the exhaust and all the bolts are tight. you can hear its comming from the motor i poped the hood a few hours ago and had a buddy come over just to make sure i wasent crazy and just hearing sh*t but he heard it. and also thought it was comming from the head. I know the timing is off beacuse the distributor was replaced and i didnt have a timing light to check but would that make a big difrence and it happens at 2100 rpm or higher its also an off beat tick or knock
1990 f22a4 ex
Old Oct 10, 2006 | 07:03 AM
standbackimapro's Avatar
How do you mess up putting a distributor on?
All you needed to do was notch the block, then make sure the new distributor shaft is in the same place as the other and put it back on.. Jesus..
Anyway, Is it a KNOCK, or is it a tapping noise?
Because a head Wouldnt knock, and if it was your car wouldnt be running
Old Oct 10, 2006 | 01:36 PM
IAWIaccord's Avatar
Default Re: (standbackimapro)
its more of a knock and i was dumb when i did the distributor. but the car still drives its just sulgish
zx92027xz
Aug 11, 2012 06:47 AM
HTn00b
Mar 10, 2007 10:17 AM
sublimenerd
Sep 8, 2006 09:54 AM
brusk13
Jan 11, 2006 07:01 PM
johnbrooke86
Aug 23, 2004 04:49 PM
