How long did it take you to install your ITR sway bar?
Old May 2, 2002 | 09:05 PM
JL 74's Avatar
25 Year Member
Default How long did it take you to install your ITR sway bar?
I didn't expect mine to arrive today. (ordered from Carland Acura). I was told it was on back order so I planned to install it this next weekend assuming it will arrive by then. Anyway, it arrived today.
The BSQ mounting kit arrived a few days ago.
Anyway, I made plans w/ the wife this Saturday (noonish), then party on Sunday.
My question, at what time should I wake up this Saturday to install it?
I know it sounds dumb, but I am really busy during weekdays, and I am itching to install this, I have been staring at it in my garage the whole night.
I know most of you know what I mean when you get something new and you want it in your car right away.
Thanks.
Old May 2, 2002 | 09:30 PM
owen_the_soyboy's Avatar
Default Re: How long did it take you to install your ITR sway bar? (jl74)
1 hr
Old May 2, 2002 | 09:41 PM
comptechgsr's Avatar
Default Re: How long did it take you to install your ITR sway bar? (owen_the_soyboy)
45 min...
then took it to a shop, lifted it up on some air liftz
finished it in 15..
with airlifts, it should take 15
Old May 2, 2002 | 11:12 PM
98GeeYes-Are's Avatar
Default Re: How long did it take you to install your ITR sway bar? (comptechgsr)
How much was the sway bar from Carland Acura?
Old May 3, 2002 | 06:59 AM
JL 74's Avatar
25 Year Member
Default Re: How long did it take you to install your ITR sway bar? (98GeeYes-Are)
Those guys ship fast.
I got all the parts for $86.05 (nuts and bolts, etc.) plus $20 for the BBQ kit. The bar itself is $58 and change.
Old May 3, 2002 | 07:30 AM
mercury's Avatar
New User
A few hours is good enough. Worst comes to worst, you just drive around without a swaybar installed.
Old May 3, 2002 | 08:03 AM
96IntegraLS4DR's Avatar
Took me 30 minutes to install and at the time,
I had access to overhead lift, air tools.
Old May 3, 2002 | 08:20 AM
JL 74's Avatar
25 Year Member
Default Re: How long did it take you to install your ITR sway bar? (96IntegraLS4DR)
It will probably take me longer since I don't have an airlifts. See my post on jackstands.
How about the drilling part, is that a pain. I have POS drill and I am not sure if it has enough torque to actually drill through a metal. TIA.
gandhisan's Avatar
Anybody know the # for Carland Acura?
Old May 3, 2002 | 08:22 AM
JL 74's Avatar
25 Year Member
Default Re: How long did it take you to install your ITR sway bar? (gandhisan)
1800CARLAND
Old May 3, 2002 | 08:46 AM
BSQ's Avatar
BSQ
The 2 holes only need to be enlarged slightly (approx. 1/8"), so the drilling is really easy. I would be suprised if it took you more than 10 seconds each on the holes.
Old May 3, 2002 | 09:15 AM
1996GSR's Avatar
Default Re: How long did it take you to install your ITR sway bar? (BSQ)
It took me a little over an hour, only because the one of the tack-welded nuts was somewhat difficult to get off. Other than that, pretty quick and easy.
Old May 4, 2002 | 09:51 AM
JL 74's Avatar
25 Year Member
Default Re: How long did it take you to install your ITR sway bar? (1996GSR)
I have spent like 30 minutes trying to remove the rt side tack welded nut. The one on the right popped off after a couple of good solid hits, the one the left, messed up my chisel.
I need HELP.
Old May 4, 2002 | 11:12 PM
Mike B's Avatar
How did you remove the tack weld nuts? I drilled but they didnt budge. Anyway, I installed it with them on it.... *shrug*
Old May 5, 2002 | 12:12 AM
mercury's Avatar
New User
Sharpen your chisel with a grinder or just go buy another chisel. I don't entirely agree with the screw a bolt partway in and whack it with a hammer method.
Old May 5, 2002 | 12:14 AM
mercury's Avatar
New User
Default Re: How long did it take you to install your ITR sway bar? (Crazy Bovine)
You NEED to take those tack welded nuts off. Otherwise, it'll be like you installed the swaybar without the reinforcements and those nuts will tear right out of the subframe.
Like jl74 was saying, use a metal chisel.
Old May 5, 2002 | 07:55 AM
Isaac's Avatar
New User
Wow, you guys are quick. The ITR Swaybar was my first install and it took hours, but that's considering I didn't know crap. I had my neighbor help me out.... BTW, I installed the Beak's kit which is a little bit more difficult because you have to line both of the reinforcement plates together. You'll love the difference though!
Old May 5, 2002 | 03:10 PM
JL 74's Avatar
25 Year Member
Default Re: How long did it take you to install your ITR sway bar? (mercury)
Yes, and make sure the chisel is properly positioned at the exact edge of the nut. Give it a good whack and it will come of. This is the mistake I notice on the second nut where the chisel was in contact in the middle of the nut, not exerting enough ooomph on the weld spots. It came off anyway at the cost of my chisel. Oh well, I'll just buy another one.
Also, I am not an idiot but it took me a good couple of hours, actually more, taking breaks and cleaning up. Aligning the bolts, etc, etc, can add up time.
Another thing, on BSQ instructions, he noted using 5/16(?, or the smaller of the two) drill bit or 3/8 for enlarging the hole. The 5/16 is not large enough, and the 3/8 IMO is too big and could compromise the structure of the subframe. I used something in between where the bolt is just snug when I inserted it.
Old May 7, 2002 | 06:24 AM
BSQ's Avatar
BSQ
I used a 5/16" drill bit to enlarge the ABS sensor wire bracket (see photo below), so it will work. If you use a 5/16" bit the fit will be snug. You can also use a 3/8" drill bit if you do not have a 5/16" drill bit. There is only a 1/16" difference between 5/16" and 3/8" so there will not be any compromise of the subframe structure if you use the larger 3/8" drill bit. You could use a 11/32" or 23/64" drill bit, but they may be a little hard to find. Also a 1" (outside diameter) washer is placed between the sheetmetal and the flange nut to reinforce the sheetmetal.
[Modified by BSQ, 10:30 AM 5/7/2002]
Old May 7, 2002 | 01:44 PM
Nighthawk GS-R's Avatar
New User
half an hour man..well worth it.....
Old May 7, 2002 | 01:46 PM
JL 74's Avatar
25 Year Member
Default Re: How long did it take you to install your ITR sway bar? (Nighthawk GS-R)
Must be a record time.
Old May 7, 2002 | 02:06 PM
New User
LOL the hardest part was unbolting the exhaust...
[Modified by Nighthawk GS-R, 6:06 PM 5/7/2002]
Old May 7, 2002 | 02:19 PM
JL 74's Avatar
25 Year Member
hahaa, the reason I said record time, because that is the time (30 mins) I spent getting that damn tack nuts out , including break time and swearing.
usmarinedelta
Dec 25, 2006 09:36 PM
njandrewg
Jan 29, 2005 07:15 PM
silvrintegra
Jun 15, 2003 05:12 AM
One Bad GeeSeeR
May 6, 2003 04:46 PM
InTeGrA_bLazEd
Dec 20, 2002 04:00 PM
