should i install a ignition?
Old May 6, 2002 | 11:22 PM
homegrown96734's Avatar
Default should i install a ignition?
i got a cheap msd 6al with a blaster3 coil..should i install it ..i heard that my c.e.l will come on after a while.thanks for all tha advise
Old May 6, 2002 | 11:33 PM
brinks's Avatar
Default Re: should i install a ignition? (homegrown96734)
most say gains will be small to none. I saw a slight improvement in mileage. The main reason I am using it is for the rev limiter.
Old May 7, 2002 | 12:20 AM
SIK IN DA HED's Avatar
New User
Default Re: should i install a ignition? (brinks)
it wouldnt hurt to install it. probably get better combustion and smoother powerbands. the stock ignition is sufficient but the multiple spark capacitative discharge feature of a MSD unit works best for forced induction. install it since you already got it. your CEL wont come on unless u installed it wrong or the unit is defective.
Old May 7, 2002 | 12:21 AM
green_GSR's Avatar
If you install it properly, your car shouldn't throw any CEL codes.
I don't see any negative effects in installing the MSD box and coil.
Old May 7, 2002 | 02:26 PM
dariusz's Avatar
In this configuration, add the MSD distributor cap for beter result...
korndog
Apr 14, 2008 12:01 PM
1320DRAGWORKX
Nov 3, 2006 06:45 AM
scrubachu
Sep 26, 2001 02:32 PM
