Water out of Exhaust
Old Oct 9, 2006 | 11:16 AM
Magick211's Avatar
Default Water out of Exhaust
I put in a used d15b2 in my hatch last night. the motor has been sitting for a few years. it starts up and runs fine. Now i know that a lil condensation out of the exhaust is normal but this one is gettin a lil more then normal. If i rev it up i see lil speckales on the ground about 3 foot out.
The car has stock exhuast almost all the way back and connects to a 2-1/4" axle back. Could the differnt size pipes have anything to do with creating more condensation? Also i dont think its the headgasket because it is not smoking at all.
Old Oct 9, 2006 | 11:19 AM
nexgen91's Avatar
it shouldnt, is there any oil in the water?
Old Oct 9, 2006 | 11:21 AM
Magick211's Avatar
Default Re: (nexgen91)
well the water is mixed with some black stuff but its carbon build up i think. I havent really driven the car yet only let it idle for 5 to 10 minutes a few times
Old Oct 9, 2006 | 11:25 AM
nexgen91's Avatar
Default Re: (Magick211)
my old d15 did that to but I was running open cat/custom race muffler. its not normal i do know that. not sure what it is though. does it smoke at all?
Old Oct 9, 2006 | 11:26 AM
Magick211's Avatar
No smoke, maybe its the cat causing it
Old Oct 9, 2006 | 11:56 AM
nexgen91's Avatar
sorry but I have no clue dude. wish i could help ya out. maybe it is just extra condensation from the engine setting.
Old Oct 9, 2006 | 12:08 PM
Magick211's Avatar
I know a bad intake manifold gasket can cause coolent to get into the engine but it would be smoking white if that was the case, right?
Old Oct 9, 2006 | 12:20 PM
nexgen91's Avatar
yeah, i think thats right. it might be the ex mani gasket though
Old Oct 9, 2006 | 07:13 PM
BlueCrxNC's Avatar
A clean burning motor creates the following:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The main emissions of a car engine are:
Nitrogen gas (N2) - Air is 78-percent nitrogen gas, and most of this passes right through the car engine.
Carbon dioxide (CO2) - This is one product of combustion. The carbon in the fuel bonds with the oxygen in the air.
Water vapor (H2O) - This is another product of combustion. The hydrogen in the fuel bonds with the oxygen in the air. </TD></TR></TABLE>
-- From http://www.howstuffworks.com/c...1.htm
Simple search even locally:
https://honda-tech.com/zerothread?id=1568437
All, in all. You're fine. That water vapor is cooling down/condensing as it exits your exhaust and turning into the liquid form you are seeing. I always blow a 3 ft mist/spray of water when revving up after sitting at idle for a while. I've even left a few carbon stains in a few driveways (water evaporates and carbon that came out of the exhaust with the water is left behind)
Old Oct 9, 2006 | 07:19 PM
salman's Avatar
hehehe.
thts noting to worry about,
Only ur head is working in perfect condition,
MopdiT
Jan 26, 2008 05:49 AM
mk2
Jan 5, 2005 11:26 PM
Nextelbuddy
18
Feb 18, 2004 04:53 PM
Gen5lude
Apr 7, 2003 03:04 AM
integrx
Sep 12, 2002 09:47 PM
