f22b motor swap questions about knock sensor
Old Oct 9, 2006 | 09:10 AM
donldon's Avatar
Default f22b motor swap questions about knock sensor
I swaped an f22b jdm with a h23a1. i got a check engine for a knock sensor. i was told to use the same sensor off the h23 but when i go to put it in the sensors threads are to big and wont fit. it seems that oil will leak if that hold is left unplugged does anyone have any knowledge of this?
Old Oct 9, 2006 | 01:17 PM
prelittlelude's Avatar
Default Re: f22b motor swap questions about knock sensor (donldon)
all holes for knock sensors are blind, i don't even know if the f22b comes with a knock sensor. all honda knock sensors have the same thread, just a different plug. i think you unscrewed the oil sensor.
if your f22b block doesn't have a spot for the knock, get a nut from home depot with the right thread and weld it onto the back of the block there should be a cast iron coolant port plug, either that or weld it to the altornator bracket
Old Oct 9, 2006 | 05:04 PM
f22b_dohc's Avatar
there are blank holes under the oil filter on the f22b you have to thread it
it would seem easier to weld a nut to the alt bracket......
Old Oct 10, 2006 | 06:00 AM
donldon's Avatar
so your saying if i weld a nut to the altornator bracket and thread an sensor then that will work as a knock?
Old Oct 10, 2006 | 06:16 AM
MadCityLude
Guest
Posts: n/a
Default Re: (donldon)
Yes, all it does is hold against the block.
Old Oct 10, 2006 | 01:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donldon &raquo;</TD></TR><TR><TD CLASS="quote">so your saying if i weld a nut to the altornator bracket and thread an sensor then that will work as a knock?</TD></TR></TABLE>
im not saying it will acurately detect knock but the ecu will see enought knock voltage to know there is actually a sensor wired in and not throw a code
Old Oct 10, 2006 | 04:30 PM
f22b_dohc's Avatar
Default Re: (prelittlelude)
thats exactly what i need lol
limp mode sucks
gabrielsousa
Nov 4, 2015 04:12 PM
JDMislander
Mar 26, 2010 06:01 AM
rorik
May 27, 2008 05:48 PM
Universal Magnetic
Oct 22, 2003 11:44 PM
B.
Sep 3, 2003 04:32 PM
