Noise from Driver Side
hey , around last year of June, i was an accident where my upper ball joint, lower control arm, shocks and springs radius rod, were damaged and paid to get it fixed. Ever since, i would hear this low and distinct rumbling front that front driver side tire like if the shrowd or something is rubbing on it. Now im under the impression that it is the wheel hub and the bearing. But i dont think that would cause the used tire that i bought where the noise was present to blow p on the i-95. What do you guys think?
2002 Honda Accord dx 71k
Excuse me, let me reiterate my problem. Around june of last year, i was involved in an accident that torn by ball joints, bent my control arm, knuckle, radius, tie-rods, strut and spring. The only thing that was not replaced was the bearings. So after everything was replaced and buying a used to tire to the Virginia, I would hear a loud jack hammer like noise coming from that driver side tire, then suddenly the tire bursts. Went to complain to the body shop and i couldn prove a sticking metal that would cause that. I bought new tires and that same distinct noise would modulate due to the increase of speed on the highway. That leaves me to suspect that the wheel hub and bearings are finished. What do you fuys suggest?
Mishako129
Jul 18, 2013 02:25 PM
cvrtsniper
Dec 14, 2009 09:09 AM
