Car cranks but wont start
I was driving my car the other day and it started to hesitate and I was just driving through town at 25mph when it happened and it just got worse and worse as I drove home. When I got home I installed the stock coil in it to see if the external msd was the cause. When I started it, it sounded like it was running on like 2 cylinders and I unplugged one of the wires and it died and wouldnt start. So I replaced the distributor with a brand new one and it cranks and sputters like it wants to start but wont. Also when its cranking it turns over like 3 times fast and slows down the 4th. I checked the timing and it was fine but just to be sure I reset it and it still did the exact same thing.
sounds like its washed down, put a little oil in each cylinder to help seal the rings and try again, if it starts, burn off the oil then change plugs. It sounds like they are all very black.
94b16teg,
Its not againt the rules to hijack another thread since you have the same problem BUT you are going to need to give tons more info before anyone can help you.
SORRY, PRESSED THE WRONG BUTTON AND REPLIED TO THE WRONG THREAD, SORRY
bauergold
Jul 28, 2017 05:15 PM
BolivianFuego
Apr 9, 2011 09:34 AM
bart simpson
15
Apr 6, 2010 12:21 PM
