for does with intakes
Old Oct 8, 2006 | 12:19 AM
Extreez's Avatar
Default for does with intakes
well 99% of us have intakes here so yea, got a question when you hose off your engine for clean what do u do to ur intake so it doesnt suck in water once u start the motor u put a bag over it ? or what ?
Old Oct 8, 2006 | 12:49 AM
jdmintegralsvtec's Avatar
Default Re: for does with intakes (Extreez)
yes. i put a plastic grocery bag from safeway or food 4 less over it. i tie it around the filter. i also cover the dizzy.
Old Oct 8, 2006 | 04:29 AM
Armed Ferret's Avatar
Default Re: for does with intakes (jdmintegralsvtec)
what about bucks with intakes? or fawns?
Old Oct 8, 2006 | 09:51 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Just take the whole intake off, and then tape your TB shut.
Old Oct 8, 2006 | 09:55 AM
arrojj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Extreez &raquo;</TD></TR><TR><TD CLASS="quote">well 99% of us have intakes here so yea, got a question when you hose off your engine for clean what do u do to ur intake so it doesnt suck in water once u start the motor u put a bag over it ? or what ?</TD></TR></TABLE>
i think every one that owns a car has an intake or else there car would not be able to run
Old Oct 8, 2006 | 12:38 PM
aaronISthrowed's Avatar
Default Re: for does with intakes (arrojj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arrojj &raquo;</TD></TR><TR><TD CLASS="quote">
i think every one that owns a car has an intake or else there car would not be able to run </TD></TR></TABLE>
I have a charge pipe and my car runs
Old Oct 8, 2006 | 01:14 PM
MINTGRN4DR's Avatar
hmm i have an injen polished pipe and its not so polished no that i pressure washed everything i should have taken it off
Old Oct 8, 2006 | 01:46 PM
Leo C's Avatar
Night Owl
Default Re: (MINTGRN4DR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MINTGRN4DR &raquo;</TD></TR><TR><TD CLASS="quote">hmm i have an injen polished pipe and its not so polished no that i pressure washed everything i should have taken it off</TD></TR></TABLE>
You don't have to take it off. Just tape a plastic bag around your filter, as well as your distributor, battery, and fusebox.
Old Oct 9, 2006 | 12:53 PM
MINTGRN4DR's Avatar
no i did use a plastic bag i sprayed purple power on all the oil from previous owner and used a low power pressure washer and now my injem polished pipe doesn't look polished it looks like the clear coat all washed off or something and i tried using a metal polish but it failed
Old Oct 9, 2006 | 01:56 PM
Leo C's Avatar
Night Owl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MINTGRN4DR &raquo;</TD></TR><TR><TD CLASS="quote">no i did use a plastic bag i sprayed purple power on all the oil from previous owner and used a low power pressure washer and now my injem polished pipe doesn't look polished it looks like the clear coat all washed off or something and i tried using a metal polish but it failed </TD></TR></TABLE>
Spray that bitch flat black. Or get some 800 grit and work your way up, then use the metal polish.
ilovemyh22
Dec 23, 2009 09:14 PM
SoyMilk
May 5, 2007 04:40 PM
vteckyle
Dec 29, 2006 10:14 AM
MAX PAYNE
15
Aug 16, 2006 06:26 PM
zseeanz
Oct 22, 2002 07:51 PM
