a little guru help
Old Oct 8, 2006 | 06:06 PM
raphael's Avatar
Default a little guru help
i have a 96 civic that i bought with an alarm. my problem is that sometimes wen i try to start it i wont even crank. other times it starts great no problems. and it wil always start if i jump the starter. wtf is going on? could it be the alarm system f#$%in my car up or wat? any ideas would help thanx fellas
Old Oct 8, 2006 | 07:27 PM
a1320addict's Avatar
Default Re: a little guru help (raphael)
Could be a ton of different things, but the alarm could be the cause.
Doulbe-check all connections to the starter and ignition. Worst-case scenario, remove the alarm and re-install it. If something's going on, on that end, you're better off with a proper wiring job.
Old Oct 8, 2006 | 09:24 PM
integ401's Avatar
Default Re: a little guru help (a1320addict)
dude my car did the same thing on wednesday. What kind of alarm do you have? The alarm i have has a starter kill and has a mind of it's own sometimes
Old Oct 9, 2006 | 06:39 AM
raphael's Avatar
lol sounds like our alarm system should hook up cuz they both have AI.im not sure what kind of alarm it has i dont know where to check that.do u?
Old Oct 9, 2006 | 04:37 PM
dartdc97's Avatar
Default Re: (raphael)
before you start disassembling the alarms, you guys should check the booted connection on your starters. sometimes they can have a bad connection or disconnect completely from hard driving vibrations. its right on the top of the starter, try pushing it in...
ipleadthe5th
Audio / Security / Video
16
Apr 21, 2017 06:49 PM
EMILYKHAMPOU
17
Dec 21, 2014 09:15 AM
blks2k3
25
Apr 10, 2005 10:40 PM
aquarius
Jul 15, 2004 07:53 AM
Confused
Aug 4, 2003 09:24 AM
