Brakes rattling
Old Oct 8, 2006 | 03:28 PM
Benhawk's Avatar
Default Brakes rattling
First off I would like to say hello to everyone at HT, and that I am fairly new to HT. I have a 95 LS, and since buying it a little over a year ago, I have had this problem with my brakes. Every time I hit a bump or ride over rough pavement, my brakes rattle, and when I apply my brake pedal while driving the noise will stop. It seems to be just my L/R brakes, in which I also have an ABS code 48 which means bad sensor in the L/R. I am just curious and would like input if this has been a problem for anybody else in the past. Thanks!
Old Oct 8, 2006 | 03:33 PM
HGZ's Avatar
HGZ
Default Re: Brakes rattling (Benhawk)
i have this same problem with my rear brake pads. thought it was because i was using crap brake pads so i bought OEM honda pads. the rattling stopped but after awhile it slowly came back..
i just don't understand why the pads have so much room in there to bounce around like that..
Old Oct 8, 2006 | 03:49 PM
Miracle's Avatar
Default Re: Brakes rattling (HGZ.)
the pads should have come with some anti rattle clips. They go on the ends of the pads inside the caliper to keep the pads tight against the walls of the calipers, therefore ending the rattle.
They are #14 in the example below:
Old Oct 8, 2006 | 04:10 PM
Benhawk's Avatar
Thanks for the detailed pic. I guess I will try replacing them, and see if it stops. I've already tried new pads, so it must be the anti rattling clips.
Old Oct 8, 2006 | 04:11 PM
Miracle's Avatar
It is when those pads move around in the caliper that you get the rattle. The rattle is the pads having freeplay in the caliper. The rattle clips are your BEST bet.
Old Oct 8, 2006 | 04:15 PM
Benhawk's Avatar
Do you know where I can purchase a set?
Old Oct 8, 2006 | 04:19 PM
Miracle's Avatar
http://www.acuraoemparts.com, or you can get them from http://www.hondaautomotiveparts.com if you know how to interchange.
Since it is an LS 'Teg, I THINK you may be able to cross reference it to a Civic of the similar year.
Old Oct 8, 2006 | 04:39 PM
Benhawk's Avatar
Thanks for your help, I found them.
Old Oct 8, 2006 | 05:24 PM
gsr dood's Avatar
yea i had the same problem last week i forgot to put the rattle clips on the rear brakes after i changed the pad and it was rattling. just get that clip in there or get a new one
92ehatch
Mar 23, 2006 07:06 PM
Poopie
Jun 25, 2004 07:03 PM
Turbo Powa
Apr 5, 2003 10:30 AM
gliaw
Nov 19, 2002 01:25 PM
RH+G
Jun 26, 2001 01:34 PM
