problem with guage cluster help??
ok I removed the needles because they were broken and i wanted to replace them with jdm yellow ones instead of the plain red ones now i tried putting them back like they were and they dont line up right im wondering what i can do to get them to all line up I think i got the rpm guage to work correct but im still iffy on the fuel guage and the temp guage to work as normal is there any way to be sure can someone help me out thanks so much
Do you remember where your operating temperature is? If so, remove the needle and let the car run until OT. Then place the needle pointing at OT. For the fuel gauge, fill up your car and stick the needle at full. For the speedo, start your car and place the needle pointing at zero above the pin.
Just*Hatched
Jun 11, 2008 08:48 AM
