Sound deadening removal
Im starting to gut my integra and in the trunk area there is a few layers of thick black junk...
Whats the best way to remove this?
Ive heard heating it up with a propane torch and scrape it out...
I was wondering if aircraft remover would work?
the tar? ive heard heat gun...i dont know if a propane torch is such a good idea. also some people freeze it up (i forgot what they use) and chisel it away.
that stuff is a pain in the ***!
I don't think chilling it will get you very far (unless you dry-ice it or something).
I'd go for a torch and then use a strong chemical (but not with the flammable remover
noooooo.... I've tried EVERYTHING and it's easiest to wait for a chilly night and go at it with some firends equipped with chisels and hammers. if it's not chilly enough, dry ice works. heat is a PAIN since it gets really gooey and leaves a sticky residue. good luck
-erik
-erik
yeah i meant that tar shiet...thanks guys..
ill try heating it up then a chemical...
i cant chisel it away on a chilly night...i just relocated to FL...i havent felt a cold night yet..LOL
i'm tellin ya, don't heat it up... it's just gonna make a mess.
go to the grocery store and get some dry ice. it's for sale somewhere near you, you just haven't realized it is my guess. it really is the best way aside from nature's cold.
-erik
-erik
use dry ice to freeze it and then chisel it out.. if you heat it up it'll just get soft and stick and cause a mess all over your tools and floor board.. I've seen people use both methods... never tried the radacator so that I cant comment on..
all stock
21
Apr 28, 2003 03:55 PM
