Spoon thermostat
Old May 2, 2002 | 06:45 PM
EleanoR's Avatar
Default Spoon thermostat
Thanks to Dave @ R&D for the Spoon thermostat. He is a good guy. i dont care what everyone else says!
I went ahead and installed it tonight. I have never done this before. Took me around 2 hours. I had to take off some stuff i didn't think i would have to take off (intake, dist cap, strut bar). The two bolts that hold the housing on where the thermostat sits were hard to get to. Oh well i put in some Water Wetter along with tap water and mixed a bit of Honda coolant to keep things lubricated. We'll see how everything holds up for the upcoming lapping sessions.
mike
Old May 2, 2002 | 07:16 PM
Flux's Avatar
Default Re: Spoon thermostat (talkie25)
for doing it yourself...
Old May 2, 2002 | 07:18 PM
Bob#455's Avatar
The Honda coolant I bought was pre-mixed...are you sure you were supposed to add water? And I think distilled water is best...
Old May 2, 2002 | 07:22 PM
SamB's Avatar
New User
Default Re: Spoon thermostat (Bob#455)
One version is pre-mixed the other is concentrate. I'm pretty sure Type 1 is concentrate and Type 2 is pre-mix.
Sam
Old May 3, 2002 | 03:25 AM
EleanoR's Avatar
Default Re: Spoon thermostat (Sam & Bridget)
Well i was going to do a full coolant flush but didn't have the time. I was planning on running a hose and flushing everything out the right way. I only had time to drain the radiator. I added a little Water Wetter at first then some water, then more Watter Wetter and mixed a little coolant with the water.
On a side note i am not sure that distilled water is better than tap water? Never heard of this.
Mike
Old May 3, 2002 | 08:19 AM
jonnybravo's Avatar
Tap water can cause rust and corrosion
Old May 3, 2002 | 11:10 AM
EleanoR's Avatar
Default Re: Spoon thermostat (jonnybravo)
hmmm...i was told my Mike K at Naples Acura that he used tap water if i remember correctly. So u think i should change to distilled water instead?
Mike
Old May 3, 2002 | 12:10 PM
FAST4DR's Avatar
Distilled water is free of any minerals which might calcify inside your radiator. Either that, or I am totally in need of a vacation!
Old May 3, 2002 | 12:12 PM
B2FiNiTY's Avatar
You should use distilled because it doesn't have the chemicals and minerals that can build up inside the radiator.
Old May 3, 2002 | 03:36 PM
EleanoR's Avatar
Default Re: Spoon thermostat (B2FiNiTY)
gotcha guys. I am going to Acura tomorrow and get some coolant and mix it with distilled water
Mike
99bb6
10
Sep 23, 2004 08:36 PM
benmasters
May 25, 2003 12:47 PM
morepoop4u
Dec 16, 2001 03:39 PM
