Max piston size+bore
Old Oct 7, 2006 | 09:15 PM
Ludeist's Avatar
Default Max piston size+bore
on a 1989 2.0si with 4ws swaped B20A Full Block+Head
Old Oct 7, 2006 | 09:58 PM
.BigSexy's Avatar
most hood white kid
Default Re: Max piston size+bore (Ludeist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludeist &raquo;</TD></TR><TR><TD CLASS="quote">on a 1989 2.0si with 4ws swaped B20A Full Block+Head</TD></TR></TABLE>
why are u saying its swapped? the B20a came stock in ur car. The stock bore is 81.5 mm with a 95mm stroke. as for boring it out, Im not sure how much, b/c I dont know how thick the cylinder wall is. if it is pretty thin, I would advise not to bore it out.
and in reference to your other thread about fitting a b16a head on ur b20a...the b20a is COMPLETELY different from the b20a/b that is found in the CRV...
so it will not work, it has been attempted, but failed.
jason007
Mar 21, 2008 12:06 PM
slacks
21
Mar 16, 2008 09:53 AM
DB1_559
Jan 21, 2007 10:31 PM
TodaB16b
11
Sep 7, 2004 10:13 AM
shotty527
Aug 17, 2003 01:16 PM
