My sunroof story...
Old Oct 7, 2006 | 05:15 PM
Sequoyah's Avatar
Default My sunroof story...
o.k. my friend Mike showed up today to help me drop the sunroof and to figure out why it wouldn't close all of the way. I took the interior plastic pieces off last night (A pillar, and the piece that is under the interior light, trim piece around door opening that fits around a pillar plastic, oh-**** handle, rear-view mirror, and the sun visors...oh and most importantly the headliner.) Be sure not to crease the headliner. This isn't going to be an ultra in-depth write up...just some pictures to help show what things look like and what the culprit of your sunroof woes might be.
What it should look like normally (passenger side on my car) :
What my drivers side looked like:
While everything was off, I decided to clean everything up. I pulled the gray panel off (be careful not to break the snap clips off, you can see where they are located in the picture...5 of them I believe) 2 screws and it's off. No rust here in New Mehico. I cleaned the aluminum rails sprayed them with some lithium grease and reinstalled.
I did the same thing with the frame. I didn't take it all apart this time because I just wanted to find out what needed to be ordered, and clean it up fairly well so that when I have the parts and the time I'll disassemble everything and make sure it's good for another 15 years.
If you haven't figured out yet I haven't thrown out any technical names for anything yet, but it's evident what they are by looking in a Helms. The following pieces were the only casualties of the day. They are:
*white push pins to hold headliner in (3 or 4 of them)
*the interior piece that is attatched to the rear view mirror (the two little tabs in the back broke off)
Does anybody know if that part can be ordered?
*I didn't break the other two black plastic parts, but the two that were still on the upper track (the one that is attatched to the sunroof) were cracked where the screw holds them down and the other two were just sitting at the back of the pan.
Once I figure out the part names and part #'s I'll post back with that information.
Old Oct 7, 2006 | 06:23 PM
K20EF8's Avatar
Please weigh the whole sunroof assembly
Old Oct 7, 2006 | 06:52 PM
Sequoyah's Avatar
Default Re: (K20EF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EF8 &raquo;</TD></TR><TR><TD CLASS="quote">Please weigh the whole sunroof assembly</TD></TR></TABLE>
too late for that...I already have it bolted back in so I can drive it, but when I get the new parts and drop it again I'll be sure to weigh everything then
Old Oct 7, 2006 | 08:05 PM
Crx Jimmy's Avatar
Just weighed my whole sunrrof assembly it weighs 22lbs. , it might be off by a couple ounces because my scale only weighes in half pounds but it is accurate.
Old Oct 7, 2006 | 08:12 PM
Sequoyah's Avatar
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
Just weighed my whole sunrrof assembly it weighs 22lbs. , it might be off by a couple ounces because my scale only weighes in half pounds but it is accurate.</TD></TR></TABLE>
sounds about right...it didn't feel like the 35-40 pound # everybody always throws around here.
Old Oct 7, 2006 | 09:23 PM
Hond@'s Avatar
Default Re: (Sequoyah)
when you mean your sunroof didnt close all the way, was it tilted up at an angle and not right with the roof of the car??
Old Oct 7, 2006 | 09:32 PM
veritasaequatis's Avatar
if it helps i may be able to get some of those white pushpins that may work i use something just like them at work just let me know how many u need and the estimated or exact length and width and i'll see what i can do
Old Oct 7, 2006 | 11:04 PM
menappi's Avatar
are u trying to figure out why ur sunroof wont close? if so, check out your second pic, the plastic piece that bolts to the track is broken, same thing happened in mine, only it came unscrewed, not broken, prevented one side from closing all the way.
im pretty sure sunroof components cant be ordered, only the whole roof assembly, sorry buddy.
Old Oct 8, 2006 | 08:19 AM
cybercrx00
Guest
Posts: n/a
Hey Keith, I see you.
Anyways, I'm gonna bet that those pieces, if they are part of the sunroof assembly cannot be ordered seperately. I'm trying to identify what they are, but manufacturers tend to keep everything as a unit for stuff like this. I will keep my eyes open though, I'm looking for a panel for the sunroof on the car I'm working on.
Keep your eye out too, I think I saw a honda parts manual floating around on the internet. Might be easier to find the parts and part#'s on your own than dealing with the monkeys at the dealership.
Old Oct 8, 2006 | 08:58 AM
philkehn's Avatar
Default Re: (cybercrx00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cybercrx00 &raquo;</TD></TR><TR><TD CLASS="quote">Hey Keith, I see you.
Keep your eye out too, I think I saw a honda parts manual floating around on the internet. Might be easier to find the parts and part#'s on your own than dealing with the monkeys at the dealership.</TD></TR></TABLE>
God i love those Si rims, they are just so rare around where i live
Old Oct 8, 2006 | 09:05 AM
Sequoyah's Avatar
haha, I just got your IM...I was thinking, "who the heck is this" now I know I have a Helms manual, but yesterday I was just concerned with figuring out what was wrong with it, cleaning it and getting it back together. Tomorrow I'll make a list of parts and part #'s. I'll see if the panel is listed separately. If you ever need to borrow the manual lemme know.
Old Oct 8, 2006 | 10:25 AM
cybercrx00
Guest
Posts: n/a
probably, I had one but sold it with one of my other CRX's as part of the deal. I didn't remember part #'s though. I actually have a PDF of one now.
d87
Honda Civic (2001 - 2005)
Nov 8, 2007 09:33 AM
chadalac1712
Feb 8, 2007 01:30 PM
2fknlo
Apr 12, 2002 02:53 PM
utensil
Jun 20, 2001 09:44 PM
