17 year old coolant hoses FTL.
Old Oct 7, 2006 | 07:14 AM
SECURITY's Avatar
Default 17 year old coolant hoses FTL.
I'm trying to locate the source of a small but persistant coolant leak. it appears the coolant is coming from the base of the transmission --WTF? I'm not aware that coolant flows through or above there, but everything else in the waterpump area looks dry this morning (having run the car for 20 mins).
Help!
Old Oct 7, 2006 | 07:16 AM
Ross 2.0's Avatar
In a Junkyard near you.
it's probably running from the top of the engine down. What year exactally do you have and what model?
Old Oct 7, 2006 | 07:24 AM
Rex-Si's Avatar
Default Re: (Ross 4107)
Could be a bad line running to the iacv or fit valve , and yes what year and model.
Also what engine.
Old Oct 7, 2006 | 12:24 PM
SECURITY's Avatar
Default Re: (Rex-Si)
Thanks for the replys guys... Pretty much exactly what I was thinking (replaced the IACV/FITV early this year).
The car is an 89 CRX Si with D16z6 running obd1. It's also throwing a code 17 now and has no speedometer.
It's very strange that it had the same exact problem about a year ago, and I just filled the radiator up and it was ok.
Either way, I'm stuck at work all day today, so I'll have to do some more searching and check my pdf Hayes manual later tonight
Old Oct 7, 2006 | 10:03 PM
SECURITY's Avatar
Default Re: (SECURITY)
Code 17: VSS Variable Speed Sensor. lol.
Still not sure where my leak is coming from. But I was able to get to work and back today running tap water (), and tomorrow probably dig up a mechanic thats open
Old Oct 7, 2006 | 10:32 PM
ED9man's Avatar
Is your speedometer working?
Old Oct 7, 2006 | 10:58 PM
SECURITY's Avatar
Default Re: (ED9man)
nope!
Old Oct 8, 2006 | 08:07 AM
green91's Avatar
Maybe coolant is running down from your coolant temp sensor under the distributor? Ive also seen intake manifold gaskets leak or hoses around the fitv or iacv that can run down along the trans
Old Oct 8, 2006 | 09:29 AM
Garage 808 Hatch's Avatar
push the cable back down into the tranny. or check and make sure its still in the back of the cluster. bu it isnt uncommon for the speedo cable to break
Old Oct 8, 2006 | 10:31 PM
SECURITY's Avatar
Default Re: (Garage 808 Hatch)
Found the source: bad hose leading from the block under the distributor, to a valve going to the firewall, to the heater core, I assume. It would explain why this has started as I have been using my heater. doh.
I will post the pics if I can't find the part on schematic on Majestic honda.
Going to cut a generic 18" x 3/4" pipe and stick it on there so I can get to work this week.
Old Oct 9, 2006 | 08:39 PM
SECURITY's Avatar
Pic of the hose location
The hose
I believe it's #24 on this diagram:
Since Majestic honda shipping is too much, and I can't find the thing on SL Honda, I'll probably call my 2 local Honda dealerships and see what's up.
Someone know where to find #24 on San Leandro honda?
Old Oct 10, 2006 | 05:24 AM
Got_soy's Avatar
that hose is expensive i broke the heater valve when i tried to take the old one off. its anoying to say the least
Old Oct 10, 2006 | 05:30 AM
DaNnYsEvEn's Avatar
Default Re: (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">that hose is expensive i broke the heater valve when i tried to take the old one off. its anoying to say the least</TD></TR></TABLE> this just happend to me last night to my accord
just go to autozone i just got one cut to size for 1 buck! it ended up costing me 30 cause i broke the heater sensor right next to it....
Old Oct 10, 2006 | 05:48 AM
Hondaisok's Avatar
I replaced all of my heater hoses on my 91 civic with plain old 3/8" heater hose. I bought about 3 feet of it for under $3.00 and cut them to size myself.
Old Oct 10, 2006 | 09:37 AM
iphatcrxi's Avatar
Default Re: (Hondaisok)
my same hose had a leak too, bigass hole in it
Old Oct 10, 2006 | 09:59 AM
Malgerus's Avatar
Default Re: 17 year old coolant hoses FTL. (SECURITY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SECURITY &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to locate the source of a small but persistant coolant leak. it appears the coolant is coming from the base of the transmission --WTF? I'm not aware that coolant flows through or above there, but everything else in the waterpump area looks dry this morning (having run the car for 20 mins).
Help!</TD></TR></TABLE>
Wow, I've been having the exact same problem! I'm running an LS/VTEC and it was dripping coolant after a drive. It would be fine on idle, but when there was water pressure there would be a leak. Turned out that it was leaking from the bottom of my lower radhose, where it connects to the engine. Your rad hose could be frayed a bit and seep out coolant when you're driving. I tightened up my hose clamp and now it works fine
EDIT: Whoops, reading comprehension owns me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SECURITY &raquo;</TD></TR><TR><TD CLASS="quote">Found the source: bad hose leading from the block under the distributor, to a valve going to the firewall, to the heater core, I assume. It would explain why this has started as I have been using my heater. doh.
Going to cut a generic 18" x 3/4" pipe and stick it on there so I can get to work this week. </TD></TR></TABLE>
Nice to hear you found the problem
Old Oct 10, 2006 | 10:05 AM
justseeingifitistaken's Avatar
Default Re: 17 year old coolant hoses FTL. (Malgerus)
i used a 2000 GMC truck hose from autozone and trimmed it down....worked perfectly
jasrams
Honda Civic (2001 - 2005)
Jun 6, 2011 04:40 AM
PphamEK
Mar 16, 2009 12:43 PM
tallyBanned
Aug 18, 2006 08:50 AM
Good ol' Screwtape
Jan 29, 2004 10:10 PM
RAiMA
Jul 20, 2003 04:36 PM
